587,998 active members*
1,436 visitors online*
IndustryArena Forum > MetalWorking Machines > Hardinge Lathes > Anyone know how to replace a main spindle belt for a Conquest T42 with C axis?
Results 1 to 2 of 2
    Mar 2005
    181
    I've got to replace the main spindle belt on an old T42 built in '96.
    The manual doesn't show a procedure for changing out the main spindle belt which is contained between mounting plates for the C axis sensor assembly. I'm hesitant to remove the C axis assembly because I reckon that there are sensitive doodads inside of it. Is there a trick to removing the belt without disturbing the C axis assembly?
    Sep 2010
    196
    Re: Anyone know how to replace a main spindle belt for a Conquest T42 with C axis?
    MadMax,
    Any luck replacing your spindle belts?
    Torin...
  1. How to remove spindle cartridge VMC 1000? How to replace belt?
    By lowcountrycamo in forum Bridgeport / Hardinge Mills
    Last Post: 10-23-2015, 06:15 PM
  2. Hardinge Conquest ST-25 air leak main spindle
    By Big Daddy in forum CNC Swiss Screw Machines
    Last Post: 10-12-2012, 10:42 AM
  3. air leak main spindle Hardinge Conquest ST-25
    By Big Daddy in forum Hardinge Lathes
    Last Post: 09-11-2012, 03:41 AM
  4. Huge air leak main spindle Hardinge Conquest ST-25
    Last Post: 09-11-2012, 01:10 AM
  5. Changing the main drive belt on the spindle
    By Michael82 in forum Uncategorised MetalWorking Machines
    Last Post: 01-06-2009, 03:09 PM
