587,771 active members*
3,403 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Need some help planning out this project. A bands pin.
    Mar 2009
    296
    Trying to make pins for the band Seax to sell on their merchandise table. Could use some help planning it out. What would you do? I'm thinking use a sheet of aluminum of roadsign thickness clamped over a piece of plywood for support. Should I use a v shaped router bit to cut in between letters then an 1/8th inch dremel bit to cut it out? I can do this at the 2000 or so rpm my mill runs at can't I? But what feedrate should I use?
    Dec 2013
    5716
    Re: Need some help planning out this project. A bands pin.
    At 2000 RPM and a small V-cutter you are going to have to set the feed pretty slow. 0.5 IPM maybe? I run a 1/8, 30° V-cutter at 30,000 RPM and about 10 - 15 IPM in aluminum. Mounting a small router motor on your quill would work much better. Maybe a Rotozip or something like that. Another option is an air die grinder, or a pencil air grinder from Harbor Freight, that's what I use.
    Trying to cut the parts out with a Dremel bit may not work at all, not enough chip clearance. A 1/8 inch, 2 flute endmill would be better.
    Attachment 349488
    Mar 2009
    296
    Attachment 349488
    Thanks Jim! I'll probably try the first few at 0.5 IPM until that band has one they are sure they want many of. I thought that Dremel had a 2 flute bit that would be easy to find that I could use. Was at a Home Depot a couple days ago and saw one that says it's good for cutting holes in aluminum siding. Wouldn't that work?
    Dec 2013
    5716
    Quote Originally Posted by slashmaster View Post
    Maybe, I haven't seen those before. Use WD-40 for cutting oil.
    Should be an interesting project.
  1. Planning to Buy an old HS1
    By maquiza in forum Haas Mills
    Last Post: 04-21-2009, 01:18 PM
  2. New Project planning 12v 300amp controller
    By rkremser in forum CNC Machine Related Electronics
    Last Post: 11-25-2008, 05:22 PM
  3. Planning a 4x4
    By Oakley1975 in forum DIY CNC Router Table Machines
    Last Post: 01-01-2008, 09:21 PM
  4. My Last project (planning stage) Closed Bridge
    By Stevie in forum Vertical Mill, Lathe Project Log
    Last Post: 03-16-2006, 02:48 PM
  5. need help planning
    By russell in forum DIY CNC Router Table Machines
    Last Post: 03-18-2005, 03:18 PM
