Quote Originally Posted by Kelevra83 View Post
Hey guys,
Here's an update guys.
I've gotten the Plugin to work now and it performs beautiful, the only slight negative is a delay when adjusting spindle speed on the fly but i can live with that.
regards
Patrick
Did you change your Sact field on run screen to 2050 from 870 per instructions??
If not the plugin is continually writing frequency's and will cause a much longer delay. I strongly suggest you do this than you will also see what your RPM is at whatever percent you have spindle override set to.
