A couple of thoughts/suggestions:
You're not using G42 to compensate for the tip nose radius, so if you were to cut this part, it wouldn't look like the print (unless you have a sharp tool).
You should dimension your part print to 4 decimal places. If the start-point, end point, and radius don't add up, the control can do some weird things when interpolating arcs.
I believe your U0.1 moves in N130 and N150 should be U0.2.
Dave
