603,844 active members*
3,455 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Bridgeport S1 1 CNC w/ BOSS 5 controls: Canned Drill Cycle x-axis Rapid Travel ISSUE
    Feb 2009
    5
    Hello Everyone,
    Machine: Bridgeport series 1 CNC with BOSS 5 controls.
    Question: Why does this happen, and what is the cure?
    Problem: The problem is that when I run a canned drill cycle, the x axis goes into rapid travel and will run out to the end of the axis. I stop it from crashing by hitting the hold button. I think this problem is inherent to the system, because it was mentioned by someone who had a couple of these machines.
    The machine was originally a tape drive. I bought a rs 232 serial kit and had the machine connected to my computer. I program using notepad.
    If anyone know how to correct for this problem I would greatly appreciate instructions to resolve the issue.
    Thank you very much and have a great day!
    Best,
    Andy
    TBC Machine
    Ithaca, NY
    Nov 2004
    3028
    I have been fixing these machines since 1982 and have not seen a machine do this is programmed correctly.
    Please write a small program to program 2 deep homes (G83)
    george
  1. Int 412 shuts off on rapid Z axis travel
    By Jurek in forum Bridgeport / Hardinge Mills
    Last Post: 12-11-2007, 04:55 AM
  2. Maybe a silly question, but what controls the y axis travel?
    By alexccmeister in forum Benchtop Machines
    Last Post: 06-08-2007, 04:27 PM
  3. Canned Cycle G73 Om Control Fanuc(drill)
    By marrieche in forum Fanuc
    Last Post: 03-05-2007, 11:51 PM
  4. canned drill cycle
    By nitrosnfr in forum MetalWork Discussion
    Last Post: 05-24-2006, 04:50 PM
  5. Replies: 2
    Last Post: 01-20-2006, 08:39 PM
