588,386 active members*
5,503 visitors online*
Page 3 of 23 1234513
Results 41 to 60 of 459
  1. #41
    Dec 2007
    578
    Re: Hurco BMC20 Dynomotion Retrofit
    Ok. So does the wiring look correct.
  2. #42
    May 2006
    4059
    Wiring? Yes your description of connecting the 0-3.3V signal to a Kanalog ADC should be ok.
    Regards
    TK
    http://dynomotion.com
  3. #43
    Dec 2007
    578
    Tom,
    Jumping back to the Alarm pin wiring connection. DMM-Tech got back with me today and they gave me the opposite of what i posted before. I was thinking it should be wired as such....Minus/GND side of 24VDC supply be wired to Pin 5 (COM) of drive, then Pin 18 of drive wired to Kanalog Opto 0 minus pin and plus side of 24VDC supply to Kanalog Opto 0 plus pin.
    DMM-Tech said the following...
    "The alarm to your kanalog should be wired as:
    - Connect positive side of 24VDC to DYN4 pin 18 (alarm)
    - Connect DYN4 pin 5 (com) to kanalog OPTO_IN_PLUS.
    - Connect kanalog OPTO_IN_NEG to 24VDC negative side (Gnd)
    The resistance is already incldued in the kanalog. It says it already has a 10kohm resistance so this is ok."
    What am i missing?
    Thanks again for your help
    Troy
  4. #44
    May 2006
    4059
    Hi Troy,
    Well that should work also. Think of it like you had a battery, switch, and light bulb.
    24V supply = Battery
    DYN4 = switch
    Kanalog Opto = light bulb
    There are two options where to put the switch. Both will work.
    However I prefer our original arrangement for the following reason: I think their "COM" signal is common to multiple of their outputs (switches). If you try to wire up more than one of their outputs to more than one opto input you will find their method doesn't work.
    Here is a diagram that shows how a number of switches with a common negative terminal will work if the common terminal is connected to GND
    Attachment 356506
    HTH
    Regards
    TK
  5. #45
    Dec 2007
    578
    Good. I was understanding the common correctly then. Thanks for the light
  6. #46
    Dec 2007
    578
    Got a few more things mounted.
    Still working on wiring diagram. Currently working on wiring diagram of the TECO A510 VFD and waiting for my MPG pendant so i can get wiring diagram made for it.
  7. #47
    Dec 2007
    578
    Controling TECO A510 VFD
    Ok. Looking at the manual to my VFD i can control Speed and Direction of spindle by RS485 or second option would be Speed control by 0-10V and direction/stop control by input terminals on drive. I have plans to add a automatic tool changer down the road. Which option would be the better one?
    Thanks for any info,
    Troy
  8. #48
    Jun 2005
    1730
    Troy,
    THe use of modbus over RS485 tends to me more accurate than sending an analog voltage, depending on the hardware involved. The KANALOG has good DACs, but the other advantage is you can monitor pretty much all VFD status, current, speed, current, etc. with Modbus just have to add some code to put that information into KmotionCNC screenset.
    Russ
  9. #49
    Dec 2007
    578
    Hi Russ,
    Any idea how well the RS485 works when a potentiometer is used to override a commanded speed? The pot would be wired to a Kanalog analog input.
    Troy
  10. #50
    Jun 2005
    1730
    Troy,
    That should not be an issue at all. You will need to add some code in one of your threads, but I used modbus in Mach3 for my spindle and had a pendant with the override pot and it worked perfect. My pendant for my kmotioncnc machine does not have the spindle or feedrate override pots and I really miss that feature for my bigger machine. I guess I will need to buy a new pendant or add pots to my existing pendant. Modbus sends the commands to the VFD and the override pot would just send another Modbus command to the VFD. You can probably find someone who has already implemented this and has there C code available.
    Russ
  11. #51
    Dec 2007
    578
    Tom or anyone,
    Would there need to be a converter to use the JP10 RS232 on the Kanalog with the RS485 on VFD?
    Troy
  12. #52
    Jun 2005
    1730
    Troy,
    You will most likely need to get a USB-to-RS485 converter. This will be viewed as a standard serial port in Windows. I would think you can use the converter on the PC USB port, not certain how KmotionCNC would access a standard PC port, but I am certain they can do that.
    Russ
  13. #53
    Dec 2007
    578
    Unless iam misunderstanding something, the JP10 connector on Kanalog board will transmit the data like RS485, i just think Rs232 and RS485 are different voltages?
    Troy
  14. #54
    Jun 2005
    1730
    Troy,
    RS232 uses +/- 12V in its standard configuration. The RS485 is closer to 5V but is a differential signal carried on two wires with a common ground. If you used the built in RS232 on the KANALOG you will need to wire that to a RS232-to-RS485 converter. They sell them on ebay as I recall. If the ground on the VFD is tied to the Ground on the KANALOG then you only need two wires from the RS485 converter to the VFD.
    RS232 to RS485 RS422 Serial Adapter Converter 9 Pin Interface Data Communication | eBay
    Russ
  15. #55
    Dec 2007
    578
    Ok. You jogged my memory. I remember going down this road on another mill i had that used a VFD from Automation Direct and RS485. I have a ebay convertor somewhere as i never used it. If i go this route i will get a better converter.
  16. #56
    Dec 2013
    5722
    Your panel is looking good :cheers:
  17. #57
    Dec 2007
    578
    Hi Jim,
    Thanks. Good to here that from a "veteran" at controls. Lets me know that its the right direction. This is the most detailed and option oriented electrical enclosure i have done.
    Thanks again,
    Troy
  18. #58
    Jun 2005
    1730
    Troy,
    I like the layout of your control panel, and I especially like the fact you used several EMI filters you are doing all the right stuff. Doing all this stuff up front will help you avoid so many headaches down the road. Good Job.
    Russ
  19. #59
    Dec 2007
    578
    Thanks, Trying to be as text book as i can. And get a better understanding of how things work.
  20. #60
    Dec 2007
    578
    Has anyone used this pendant before?
    Future life Tech iHDW-FPGDL-IM
  1. Local repairman for '92 Hurco bmc20 around Bristol, IN
    By Benkerst5278 in forum CNC Machining Centers
    Last Post: 07-13-2010, 03:32 PM
  2. HURCO BMC20
    By PCM in forum HURCO
    Last Post: 05-03-2009, 08:03 PM
  3. Hurco BMC20 with Ultimax 2 control
    By kwmkoester in forum HURCO
    Last Post: 04-30-2009, 11:52 PM
  4. Hurco BMC20 Post Prosser help
    By moorport in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-06-2007, 05:19 PM
