587,129 active members*
2,869 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > Want To Buy...Need help! > Looking to buy a 3x4 CNC - What would YOU get? - Spend my Money
Results 1 to 5 of 5
    Mar 2014
    27
    Hey all...
    Im looking to buy a 36 x 48 Table.
    Currently, I am considering a Camaster II SR34 with all the bells & whistles they offer.
    I have not sent in for a quote just yet being I plan for an early 2018 delivery.
    My primary uses for the machine would be:
    Signs - HDU/Wood/Aluminum etc ... yes I know the work area is small. I can work around that.
    Woodworking doo-dads/Jigs and whatever else I think of will be made.
    I request this size table being I feel thats about the most I could get to use
    in a small garage. The footprint space I have available for the machine
    is 80"l x 72"w. The SR34 specs show it will fit. It will share the room
    w/ a Felder K500s sliding table saw.
    Looking to get the largest spindle avail for it. 3.0kw ??
    Nema 34 900oz motors
    2" gantry lift
    Misting system for Alum cutting
    Vacuum table
    Ok, so those were some options from the PDF sheet.
    Now for my question:
    Is there other companies out there that have a table size
    of 3x4 that are better than Camaster or equiv?
    Within the -$20k range?
    I'd like something with strength, power and to know I could get it done.
    I just wish some companies would make a shorter version of
    their machines for us folk. What also sucks is regular workdays
    I use a Multicam 3000. No comparisan obviously.
    If you were to buy a machine @ 3x4 and make it the strongest,
    most powerful, what would you get? Just remember to keep me under $25k max
    and within the size area as mentioned above.
    Thanks all!
    35538
    Re: Looking to buy a 3x4 CNC - What would YOU get? - Spend my Money
    Move up to a Panther or Cobra 4x4, if it'll fit. You can get a 4Kw spindle on a Panther.
    Shop Sabre may make something similar.
    You could build a serious machine with $20,000, if you wanted to go that route.
    Mar 2014
    27
    Gerry,
    I appreciate the 'upgrade' but I cannot go any larger.
    The CM SR34 for now seems to be the best fit. I have
    a sliding table saw that sliding from the door to the machine (SR34)
    I will just be short of 2~5".
    Oh wait there's more. My door opening is 59". The garage rollup was removed
    and replaced with split double doors. I dont feel like doing a circus act with a
    machine to get in.
    Yes, I do want a serious machine. For now Im not worried about this size, it's perfect for my home.
    Anything larger I can do at my job on the 5x10.
    Camaster wont budge to make a smaller 'custom' made 3x4 in those series.
    Gonna try bugging them again to get a 3x4 Panther at least.
    Not sure of Shop Sabre, but i'll give them a try.
    Any other companies to look into?
    Thanks again for your reply!
    35538
    There's really no market for small, heavy duty machines in the $20,000 range.
    The Shop Sabre has ballscrews, which I'd prefer in a machine that size. You should be able to get a bigger spindle, and AC servos and still be in your price range.
    Afaik, both the Shop Sabre and Camaster both use the WinCNC control.
    I'm not aware of any other competitors to these two.
    falacncrouter Guest
    Hi dear friend. We can definitely meet your requirments. Please enter this page to send enquiry to us: Enquiry China CNC Engraving Machine from FALA CNC . We will send quotation to you soon.
  1. What should I spend my money on? Cnc plasma
    By sroutley in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 01-17-2017, 10:32 PM
  2. VXB bearing $20 off when you spend $100
    By pippin88 in forum Benchtop Machines
    Last Post: 06-30-2014, 06:24 AM
  3. How much do you have spend ?
    By Nils P. in forum Uncategorised CAM Discussion
    Last Post: 02-13-2014, 08:31 AM
  4. $10k to spend. Where to put it.
    By InfernusDoleo in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-21-2012, 05:44 PM
