588,211 active members*
3,993 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Huanyang Chinese VFD settings and manual here!
Page 19 of 41 9171819202129
Results 361 to 380 of 808
  1. #361
    Mar 2010
    813
    Re: Huanyang Chinese VFD settings and manual here!
    I think vid should be working now.
    I use a shielded 18-2 stranded copper wire, I bought a roll of it in HD when dong limit switches. The Usb sometimes can be hit or miss but that's what most use, I think it could be more susceptible to noise but never used one. If you have a serial connection I suggest that one, no additional drivers needed and never read of any having trouble with it.
    Dan
  2. #362
    35538
    I need to use USB with the laptop I'm using, so I just ordered one from Amazon with Sunday delivery, for $7.
    So, I just spent two hours testing.
    I made a new cable to the spindle, with twisted wires. (Swapped two wires for correct rotation).
    I grounded the spindle to the VFD.
    I twisted the power cables supplying the VFD (but only after my distribution blocks). There's a heavy cord plugged into the wall before that.
    I changed the REV terminal to Forward Rotation (PD045 = 2).
    It runs exactly the same as before. Only with the correct rotation, and the FOR LED lit up on the VFD.
    I also changed the carrier frequency. It made the motor quieter, but no change in the fluctuations. It was at 3, I changed it to 6. (Also tried 8 briefly)
  3. #363
    35538
    Dan, is the 11 amps the current that the VFD is drawing?
    When I set the VFD to display amps, it shows 1.1-1.4.
  4. #364
    Mar 2010
    813
    No, its the out amps, the current the spindle is drawing, I have a 3kw spindle.
    I mentioned in other threads that the HY only reads running frequency for RPM(most...if not all) and if under load it wouldn't show in RPM, the VFD is going to maintain set frequency. The out amps will show/increase under load.
  5. #365
    Mar 2010
    813
    Are you sure you have it set to display Amps? It should show the letter A than all 0's when spindle not running.
  6. #366
    35538
    I thought so, but I'll check again next time I run it.
  7. #367
    Mar 2010
    813
    Sorry read and answered to quickly, that seems right although high. The plugin reads set amps(PD142) than adds the out amps. If you have a 2.2kw and have PD142 set to 9 amps than the spindle is drawing 10.1 - 10.4 amps. I'm almost certain I'm interpreting this correctly.
    My motor plate reads 11 amps and what's set in PD142. The amp display shows 0 when spindle not running. When running shows averagely 0.0 to 0.2, it increases on acceleration and deceleration.
    Dan
  8. #368
    35538
    I think it's set to 8.5amps. The spindle doesn't list the current, but that's what they show in the Ebay listings for the air cooled spindles.
  9. #369
    Mar 2010
    813
    Well than according to my calculations spindle is drawing 9.6 - 9.9 amps. To me this seems high with spindle under no load but then again it's not my field and I hope some1 post to elaborate. Possibly spindle manufacture lowers set amps deliberately??
    Attachment 358862
  10. #370
    Mar 2014
    735
    My 2.2kw spindle only draws ~1.7 amps at 24000 RPM with no load. I'm using an Hitachi VFD. If your no load current is 9 amps that seems too high.
    PD142 looks to be the spindle name plate amp rating. What ever value is set in this parameter will limit the output of the VFD, is how I read it.
    Sent from my Pixel XL using Tapatalk
  11. #371
    Mar 2010
    813
    I assumed differently and was incorrect. What threw me off was when my 3kw spindle started at 6000 rpm my readings was 0.0 to 0.1, at 24000 rpm no load readings are 0.4 to 0.6. I didn't think this was possible and lead me to believe what I posted.
    Dan
  12. #372
    May 2017
    8
    Hi Guys,
    I came across this thread searching "HY04D023B" as that's the VFD that I ordered. I plan to use this for a 5hp 3 phase old planer.
    I haven't even ran wire to mine yet. I would like to run a 20ft cord with a 10-30r nema male plug on it so I can plug it into my dryer outlet. The manual confused the sh** out of me and I've been too busy past week to look further.
    I plan to remove the on/off switch on the planer and 'reset' box so the VFD is wired directly to the motor. Is wiring an on/off switch between the wall and VFD needed if I plan to plug and unplug it when needed?
    Does anyone have recommended parameters I should use? Might be asking a lot so let me know. A soft start and soft wind down would be good. I won't need variable speed.
    The motor is a 5hp 12 full amps draw.
  13. #373
    15362
    Quote Originally Posted by Psychbiker View Post
    Hi Guys,
    Yes that's an easy one to do, is the switch on the machine for 240V single phase, if it is it is best to use a switch to turn the power to the VFD ON /OFF, what RPM is the motor, and what RPM range do you want to run it at
    Mactec54
  14. #374
    Dec 2003
    24220
    Normally you would wire the 240v into the enclosure together with the VFD, The existing contactor/disconnect SW would be used to drop power to the VFD input on an E-stop, as per most VFD instruction manuals.
    Al.
    Albert E.
  15. #375
    May 2017
    8
    Yeah, the switch is on the machine, then goes to a box that says (reset) then to the motor.
    Pic of motor tag. I'd like to run it at it's full 3400rpm. Pic of similar machine below. Mine is belt drive motor, not direct drive, but shows the on/off switch go to a box then motor.
  16. #376
    May 2017
    34
    Quote Originally Posted by diyengineer View Post
    How to setup Chinese VFD to 2.2KW spindle.
    Picture included, as well as PDF manual.
    (I dont own the product, just figured this would help EVERYone else out that does!!)
    PDF file is 15.8MB (large). It actually is very easy to read and navigate, i was impressed on how informational it is. Hope this helps someone!
    1. I drafed the wire picture. Please see from the link: http://www.jinlantrade.com/Stock%20files/0008.jpg
    2. You can see download the inverter manual from web link:
    http://www.jinlantrade.com/ebay/invertermanual.pdf
    3. I just tell you how to set up VFD as following
    Firstly, adjust the PD013 to 8 (set the setting to factory setting)
    Secondly, adjust the PD005 to 400
    Thirdly, adjust the PD004 to 400
    Finally, adjust the PD003 to 400
    Finally, adjust the PD144 to 3000
    Note: you should set PD013, PD005, PD004,PD003, PD144 in order. It mean you should firstly set PD013, then PD005, then PD004, then set PD003, finally set PD144.
    Note: after you set the all above parameter, then please recheck the PD005, PD004, PD003 value is 400 or not to confirmed that you already set it. (note: please do not check the PD013, or all the setting will go to factory setting)
    The reason we let you recheck is that if you do not set it at 400, then when you run the spindle motor, the spindle motor will be over-current, then the spindle will very hot and then within 5 minutes, it will broken.
    That setting format dosn't look like what I have. I have a huajiang 1.5kw vfd that came with my .8kw spindle and the format on inverter display is P0-xx not the pd-xxx. Framiliar?
  17. #377
    Sep 2010
    60
    Hi guys.
    I noticed my Mach3 and spindle (1.5kW water Cooled) are not working as expected.
    The issue is: when I set the spindle speed to the minimum on Mach3, the spindleis is actually spinning at 24000 rpm (top speed).
    If I select the Mach3 spindle speed to the full steam ahead, the spindle nearly stops.
    I've tested the PWM board signal (0-10v) and the output was 9.9V when the spindle was at 24000rpm - but Mach3 was around 800rpm
    The relays are also working (it does spin CW and CCW when demanded.)
    So what I did wrong????
    Please check the snapshots.
  18. #378
    Sep 2010
    60
    [FIXED]
    Dir low active and step low active on spindle's Port & Pins had the wrong value. I unticked both now the spindle is @max speed when Mach3 is @max speed. I hope my silly mistake help this community
  19. #379
    Apr 2005
    629
    Hi all, especially Mactec54.
    I am hoping to start up my new spindle/vfd this weekend. I have read through this whole string of posts a couple of times now and believe I have extracted the details correctly to set this up. My first stage will be to just get the spindle powered up and controlled through the on-board panel of the VFD. Stage two will be to configure it to work with the MACH3 CNC software
    Here is my plan, I am hoping you can check the details so that I don't do like others have done and that is to let the magic smoke get away.
    VFD: Haunyang
    Spindle: 2.2Kw, 220V, 8.5A, 400Hz
    VFD & Spindle purchased together as a set from Ebay-Motor Mall
    VFD Parameters
    PD000=0 (Parameter change: 0=not locked 1=locked
    PD001=0 (Control source: 0=VFD panel, 1=Remote Control)
    PD002=0 (Source of operating frequency: 0=VFD panel, 1=Remote Control)
    PD005=400 (Max Operating Frequency: 0.00 ~ 400 Hz)
    PD004=400 (Base Frequency: 0.01 ~ 400.00 Hz)
    PD003=400 (Main Frequency: 0.00 ~ 400.00 Hz)
    ** Motor Mall (supplier) suggests setting PD072 to 400
    PD007=20 (Min. Frequency: 0.01 ~ 20.00 Hz)
    PD008=220 (Max. Voltage: 0.1V and up)
    PD011=120 (Frequency lower limit: 0.00 ~ 400.00 Hz)
    PD009=15 (Intermediate voltage: 0.00 and up)
    PD010=8 (Minimum Voltage: 0.1~50.0)
    PD13= 08 (to restore VFD to Factory Default Settings)
    PD014 =12 (Accel time: 0.1 ~ 6500.0 seconds)
    PD015 =12 (Decel time: 0.1 ~ 6500.0 seconds) *see note below
    PD141=220 (Motor Rated Voltage - set to voltage rating from motor specs )
    PD142=9 (Motor Rated Amps - set to Amp rating from motor specs)
    PD143=2 (Motor Number of Poles - set to information from motor mfg.)
    PD144=3000 (Max Motor RPM - Unsure of calculation to get this value???)
    * PD15 is ignored IF PD26=1 Then the Spindle will Coast to a Stop
    Wiring
    From source: 220v single phase (North America)
    3 wire, 14 gauge cable
    To
    10 AMP, 2 pole No Fuse Breaker
    To
    Dual pole switch
    To
    VFD (R = Hot #1, S = Hot #2, E = Ground wire)
    VFD to Motor: (2.2Kw, 220V, 8.5A, 400Hz)
    U to motor
    V to motor
    W to motor
    Ground to motor ground (need to remove cap and add internal ground wire to housing)
    NOTE, with cover removed, determine which pins are used on the connector for UVW.
    Cable to motor will be 4 conductor, 18 gauge, shielded, High-flex cable
    Thanks in advance for the assistance!
    Chris D
  20. #380
    Apr 2005
    629
    The vfd / spindle setup went ok - mostly.
    Configuration of the drive went well regarding parameters. Spindle started up fine, and ran fine. The spindle was even fairly well balanced with only slight vibrations.
    The cap on my motor is plastic underneath the electrical connector so connecting the ground wire there was not an option. Instead, I pulled the ground wire out from the cable insulation and routed it outside the connector. I then connected it to the spindle bracket. Easy fix.
    At present, I have a potentiometer on a remote panel to control the speed, and I have the on/off controlled by MACH3 via a relay.
    Following typical "break in proceedures" of industrial spindles, I slowly (over a period of hours) broght the spindle up to 24,000 RPM. The spindle runs a lot hotter than I would expect.
    QUESTION: How hot does your spindle get (this is the 2.2kw, air cooled spindle)? Most of the heat on mine comes from the lower bearing area. I can barely hold my hand on the spindle after it runs for about an hour.
    Chris D
  1. Replies: 6
    Last Post: 05-04-2024, 04:05 PM
  2. Car hoist 3phase settings on huanyang vfd
    By pietskiet in forum Spindles / VFD
    Last Post: 10-21-2019, 10:04 AM
  3. Huanyang SL-240EE Manual (SL Series Manual for Vector VFD)
    By Cogolith in forum Phase Converters
    Last Post: 05-24-2016, 04:19 AM
  4. Huanyang inverter PD settings
    By jamriggsy in forum Phase Converters
    Last Post: 03-15-2013, 04:54 PM
  5. Huanyang 2.2kw VFD, 0-10v 3600rpm settings?
    By EmeraldIsleforg in forum Phase Converters
    Last Post: 09-23-2012, 03:00 PM
