587,770 active members*
3,551 visitors online*
Results 1 to 20 of 142
    Jul 2007
    242
    Re: When will "acorn" release?
    Acorn has PLC wizard with easy drop down boxes.. the wizard programs the PLC program for you. very cool. just pick what you want the output of input to do and save it.
    i'll post some screen shots or a video of this soon.
    but if you want to you can hand edit/program the plc program. and yes it uses the same language as OAK and Allin1DC cnc control boards.
    you'd be alot happier with a centroid over hte syntec for sure!
    post some info about your machine....what axis motor and drives are you using? what kind of machine tool? etc..
    Sep 2012
    228
    Hey Keith,
    Here is a little info about the machine I'm considering Rebuilding the controller on..
    HSD 9KW ATC spindle.
    Delta VFD
    Yaskawa Servos and Motors... Sigma 7... The Y Gantry axis is dual drive obviously but both drives seem to be connected with one cable at SYNTEC that splits into two.
    Kinda a slave setup .. but different then in Mach3 or something.
    I have 2 rows o 8 linear tool forks.. for a total of 16...
    I'm actually planning to expand to 26 to 32 tools...
    I would like to setup a secondary z axis... probably with it's own servo motor...
    I hove homing switches...etc...
    I'm curious to see more about your PLC setup.
    SYNTEC uses a Ladder that can be modified with a software..
    What other info would you like?
    I do have an MPG pendant...
    What controller would you recommend.?
    Is this beyond ACORN?
    Dec 2009
    521
    Quote Originally Posted by Frankmali17 View Post
    Hey Keith,
    Delta VFD
    Curious minds want to know, what kind of machine is this? Picture?
    Like Keith mentioned, Centroid OAK sounds like it will do what you want:
    Centroid OAK Motion Controller
    It sounds like an expensive machine. You could just hire Centroid's engineers to write the PLC for you unless you are comfortable with it.
    Somehow I don't think Acorn fits this application, I don't think it has the I/O. OAK may directly interface with your servo drives.
    Show us a picture of the machine along with a description, it sounds interesting!
    Marty
    Aug 2009
    655
    Quote Originally Posted by cnckeith View Post
    Frank would be happier with Centroid - if he started with it for sure and maybe still. He and I both have syntec (now - my last machine was centroid cnc7 at the end). I knew Frank asked about centroid in the syntec thread and I have nothing but good things to say about both the hardware and the network of installers like Keith and CNCNW that work with centroid.
    Frank really seems hell bent on modifying his machine to add a ton of tools and seems to have other customization in mind that I know are not suited to a poorly documented (in english at least) Taiwanese controller.
    I absolutely love the look of that Acorn board! I agree that it is not enough input/outputs to do a replacement of a syntec (as the syntec has 16/16 and I know mine is using about 13 outs and maybe 10-12 inputs). The oak board is what I would pick and its not an idle observation as we have another machine with an older syntec controller that I can see needing replacement sooner.
    I hope to find a use for that Acorn board - I would be nice to use the centroid control software again. I still might too. I have an engraver project using Tinyg board and really, if this had been out earlier, I might have gone centroid for it just for the controller software. Anyhow, to anyone researching it, that Acorn board looks awesome. I wouldn't touch Mach 3 with a 10 foot pole (It seems like a kludge on top of a patch to me) and this looks so much easier and so much better. Not that I use a gecko 540 but that particular db25 feature looks so awesome to someone like me that struggles with neat enclosures.
    Anyhow, just wanted to see the praises - my previous machine was great and it was built in 2000 with older tech. These have all the benefits of modern tech and the simplicity of a tried and tested user interface.
    In case anyone is wondering, I'm the twin of the other gfacer on cnczone...
  1. Replies: 5
    Last Post: 01-12-2014, 07:07 PM
  2. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  3. WE-CIM Educational Packages "Press Release"
    By jwittlock in forum News Announcements
    Last Post: 09-20-2012, 06:09 PM
