603,980 active members*
2,617 visitors online*
Page 3 of 22 1234513
Results 41 to 60 of 438
  1. #41
    Oct 2005
    36
    HI
    thank you smarbaga.
    this is very good designe of power amp for
    servo.
    but i need a schmatic of attiny2313 servo
    controler with hex file do you have it.
    Any help appreciated.
    Best regards
  2. #42
    Mar 2005
    523
    hello Nasr1
    attached below is the schematic, i don't have the firmware downloades for the elm, but i think it can be had from the elm's home sight, which i don't know what is it right now but it is previous posts.
    Attached Files Attached Files
  3. #43
    May 2006
    190
    hello Nasr1
    Compiling the smc software is very easy. Download AVR Studio, load the source file and click compile. It will result 2 files. The hex file and an ".eep" file. both files should be uploaded to the attyny2313. The hex is the program itself and the eep contains the initial servo parameters(I think). Use ponyprog to upload the files to the chip. Take good care when setting the fuse bits. You may "brick" the chip if using wrong settings here. You will find in the picture how the fuse bits must be set for the elm servo to work.
  4. #44
    Oct 2005
    36
    hello All
    thankful for answer.
    I compiled source file with AVR Studio (smc.zip)Please turn 2 attached file . but this hex file its good for lpt port input.I used attyny2313 and l298 for
    drive 3Amp servo motor with sharp encoder. i have problem with RS232 input (PIN 2&3 txd and rxd of attyny2313) do it might be possible defective source file .? can you test this file (smc2).?
    Best regards.
  5. #45
    May 2006
    190
    Sorry but I do not have anymore a smc board to test your files. However check the following:
    Cable connections (misleading of tx and rx)
    SYSCLK in the source file (must be the same with the crystal)
    Fusebits settings (if not setting CKDIV8 i think, the chip will use it's own clock generator instead of the crystal)
    Settings of the HyperTerminal connection (38.4k bps, databits 8, parity none, stopbits 1)
    Best regards
  6. #46
    Oct 2005
    36
    Quote Originally Posted by mcm_xyz View Post
    Best regards
    hello
    thanks for your answer.
    I am try to test it.
    Best regards.
  7. #47
    Apr 2005
    26
    Ckdiv8=1?
  8. #48
    May 2006
    190
    Not sure what 1 and 0 means (set ur unset)...
    Look at the picture with Fuse settings previously atached...
    When you read the fusebits form a fresh chip the ckdiv8 is checked. I had to uncheck it... At least with ponyprog...
  9. #49
    Apr 2005
    26
    p1
    200
    p2
    50000
  10. #50
    May 2006
    190
    so it is working... :cheers:
  11. #51
    Oct 2006
    7
    I am new here and being a newbie, wish to build the ELM DC servo controller. Anyone who have completed and who like to share their knowledge would be greatly appreciated.
  12. #52
    Dec 2006
    3
    HI
    thank you smarbaga.
    servo.
    Best regards
  13. #53
    Mar 2005
    523
    hello:
    i don't have the source, hex file for the atmel.
    attached is the schematic.
  14. #54
    Apr 2005
    26
    74hc08+74hc14+ir2104*2+irf540*4+2313+A2631 and smc3a
  15. #55
    Dec 2006
    3
    hello
    I see this parts but i dont know other parts value and sch.?
  16. #56
    Dec 2006
    3
    ir2104,irf540,motor voltege 24v are problem?
  17. #57
    Dec 2006
    18
    Does anyone have the PCB file for this controller?
  18. #58
    Oct 2006
    7
    I have test the ELM servo controller using SMC3 source, the control circuit using ELM and the FET use UHU and it work! The only problem I facing are tunning the servo parameter.
    The chip I using are 74HC14, IR2184*2,IRF540*4,2313.
    Anyone can help to tune the correct servo parameter?
  19. #59
    May 2006
    190
    Hello
    Check this out.
    It seems somebody has developed a pcb for ELM controller
    http://www.emtech.ovh.org/
  20. #60
    Jul 2005
    442
    Check this out.
    Take a look at the schematic - you might have a few issues with your FETs running that circuit.
    Aaron
  1. Central PID Controller vs. PIV Controller in each Servo Amp
    By Bronx68 in forum CNC Machine Related Electronics
    Last Post: 11-20-2013, 05:33 PM
  2. Servo Controller pin out ?????
    By slowtwitch in forum Servo Motors / Drives
    Last Post: 05-28-2013, 03:55 PM
