Hi guys,
I'm getting ready to test a new (old) router, but the spindle is too low - with a 6mm x 30mm (ish) end mill in the Z height probe won't reach the workpiece.
Is there any problem backing off the spindle mounting bracket and raising the spindle up 30mm or so?
pretty sure I can re-calibrate the tool height measuring setup, but will I have to get a new distance ring for the spindle holder / clamp?
The machine was designed for chamfering steel plates with sub 3mm short bits - was never setup for general cnc milling / routing
Cheers
Simon
