Re: Sequential numbering howto?
Originally Posted by
Blackened
cinematic2, these are all formats for use with CAD software of some description. G-code comprises the lower level instructions that cause many machines to move in a straight line or an arc etc... along with feedrate, power and all manner of machine instructions. You can often edit the g-code manually after CAM software has post-processed a job and do all sorts of wonderful things that the CAM software may not do out-of-the-box.
I know pretty well what G-codes are. I use it for 20 years on engraving/milling machines that I build.
But you will NOT use G-codes on any laser engraving machine with standard mainboard.
As long as you will make a special purpose one.
CNC lasers, constructions, service
