587,201 active members*
3,044 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Variable for reference position (G30)
Results 1 to 8 of 8
    Jan 2010
    171
    Anyone know the variable for reference position? parameter 1240
    I wanna modify the toolchange cycle and i want it to feed to the position and not rapid.
    May 2016
    526
    Re: Variable for reference position (G30)
    Dependant on the controller and if the tool change macro is available for modifiction if it s its easy to change
    If not you may have to adjust the rapid parameter for the machine
    Feb 2006
    1792
    Why waste time by feed motion to the reference position. If it is lathe, first home X. If a milling machine, first Z. These are safe motions. Can be at rapid rate.
    Jan 2010
    171
    Quote Originally Posted by sinha_nsit View Post
    There is a reason why i wanna feed my machine to secondary reference position, i specified G30 not G28.
    Jan 2010
    171
    Quote Originally Posted by mbservice View Post
    Tool change macro is available for modifications, i can put all the coordinated inside the macro but there is a parameter which doesn't allow tools to be unclamped/clamped if the machine is not in some of the reference positions, i wanna keep this option ON, i can put the same coordinates inside the problem but i would rather get the directly from parameter 1240.
    Parameter 1241 is the value for G30, if set to 0 then it will go to the same place as G28.
    Jan 2010
    171
    #100=PRM[1241]/[1] is what i'm after.
    Feb 2006
    1792
    It would work on model D, but not on earlier models where PRM is not defined.
  1. Altering reference position
    By samu in forum Fanuc
    Last Post: 12-19-2012, 09:45 AM
  2. Adjust Reference Position Return - 10M
    By Swemill in forum Fanuc
    Last Post: 09-28-2011, 04:03 AM
  3. VMC1000 HH 426 Reference Position
    By KevinV_MEI in forum Bridgeport / Hardinge Mills
    Last Post: 03-02-2011, 12:42 PM
  4. fanuc 18m g30 reference position
    By jlong58 in forum Fanuc
    Last Post: 01-31-2008, 04:09 PM
  5. Fanuc 0M Reference Position
    By inthezone in forum Fanuc
    Last Post: 07-26-2007, 07:28 PM
