587,482 active members*
3,217 visitors online*
IndustryArena Forum > WoodWorking Machines > CNC Machining Centers > motionmaster machine with fagor control
Results 1 to 7 of 7
    Feb 2018
    23
    good day to all, I am working on a machine with fagor 8055 plus-m control on the table brings motionmaster and in the tool changer kosakura bought the second-hand machine but does not bring any information; in the installation all well the problem to start the operation axes x, y, z work well the problem is that the spindle does not turn check the fagor module and everything is fine send me signal to the drive that is a magnetek GPD 515 but not remote it marks me frequently so it does not rotate, but in manual mode if the spindle rotates; someone who knows that I may be failing; I appreciate all the possible help and I do tests in manual mode and it works well but in the changes of speed I would have to be adjusting the frequency.
    regards
    Mar 2008
    169
    Re: motionmaster machine with fagor control
    DId you solve the problem?
    Feb 2018
    23
    Good day,
    Not yet, I'm reviewing the connections again and later the parameters to see if I find something that does not match; I'm working blind because it does not signal any alarm and I have no information.
    regards
    Mar 2008
    169
    Do you speak spanish?
    Feb 2018
    23
    Asi es hablo español
    where can I get a post processor for our Motion Master with a Fagor 8055. I'm using Catia as my cam system
    May 2018
    I had the exact same problem and I found it by shear luck, on my machine the limit switch and reference switch for the spindle/z axis broke and we repaired it and the machine worked fine, but after three weeks this issue arose, we open the box that the cables for the 2 limit switches lead to, (one for the spindle/z axis and the other switch is for the draw bar) The draw bar limit switch somehow disconnected itself in the box and once it was reconnected the spindle worked properly.
    If these switches are fine on your machine I would just go through the logic of the machine and see what conditions need to be met for the spindle to be turned on.
    Hope this helps
  1. Need Motionmaster 5-axis post for 8400MP AB Control
    By PrecisionD in forum Post Processors for MC
    Last Post: 08-30-2018, 06:41 PM
  2. Fagor 8055/B-M and MotionMaster problem, please help!
    By pfain in forum Fagor Automation
    Last Post: 11-19-2013, 04:48 PM
  3. Fagor/MotionMaster Commands?
    By bborb in forum Commercial CNC Wood Routers
    Last Post: 08-20-2009, 04:56 AM
