587,964 active members*
3,352 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > serial to ethernet adapter on Fanuc 0M
Results 1 to 6 of 6
    Mar 2004
    1543
    This machine followed me home from the auction:
    https://www.machinesused.com/auction...mnum=846989990
    It has a Fanuc 0M control. I need to connect this machine to a PC to do anything serious with it.
    I was researching this and came across a mention of using a serial device to ethernet converter. Apparently this will put your machine on the local network. This would be REALLY GREAT for me it I can make it work
    Here's a couple examples i googled.
    https://gridconnect.com/industrial-s...FZm3wAodqWIIew
    https://gridconnect.com/rs232-ethernet-converter.html
    I am REAL WEAK on making this **** work. Anybody done something like this?
    Karl
    Dec 2003
    24220
    Re: serial to ethernet adapter on Fanuc 0M
    Did you get all parameters and macro's? Including the 900's?
    If not the first thing you need to do is back them up once you have the communication working.
    Al.
    Albert E.
    Dec 2003
    24220
    One other thing the 0M RS232 needs is to see the hardware handshake pin levels, either the signals themselves or the pins jumpered out.
    It does not use them for HS but requires the signal present.
    It uses XON/XOFF for s/w handshaking.
    Al.
    Albert E.
    Mar 2004
    1543
    First thing I did was take a pic of every single parameter page, then install new batteries.
    i take it you have not used an ethernet adaptor, tells me not to go there.
    Karl
    Dec 2009
    972
    you can easily put the 0M on a wireless connection too using this:
    Sep 2007
    13
    Does it DNC?
    Where is the WHOLE THREAD describing this topic?
    If there is none WHY NOT?
    Thanks,
    Steve
  1. Installing HAAS VF5 Ethernet Adapter
    By PFI_IT in forum Haas Mills
    Last Post: 02-10-2016, 05:10 AM
  2. Serial / ethernet adapter - fagor 8055m
    By rwy in forum Fagor Automation
    Last Post: 02-16-2012, 02:03 AM
  3. Need some help with Ethernet-to-serial
    By kingneutron in forum Computers / Desktops / Networking
    Last Post: 11-29-2006, 08:49 PM
  4. Serial 9 pin to USB adapter
    By 2_jammer in forum DNC Problems and Solutions
    Last Post: 03-20-2006, 08:33 PM
