587,836 active members*
4,256 visitors online*
IndustryArena Forum > MetalWorking Machines > Hitachi Seikis > Hitachi Seiki Repair / Service / Support
Page 2 of 10 1234
Results 21 to 40 of 185
  1. #21
    Re: Hitachi Seiki Repair / Service / Support
    already solve my problem, thanks
    shas595
  2. #22
    Aug 2007
    793
    hello how to backup ladder on Micon 16-2?
  3. #23
    Dec 2009
    546
    @Guhl
    I sent you a PM - take a look
    John
  4. #24
    i need electric drawing and pc parameters for hitachi seiki va45 fanuc 11mf mfy 1986
    regards
  5. #25
    Dec 2009
    546
    I will see what I can find for you
    John
  6. #26
    Nov 2012
    14
    Hello, I have a problem with my vm50 (lambda 10m controller) during pallet change the emergency button was pushed . Now to do anything I need to do the referencing of all Axis , but the Y Axis is locked and cannot move either way. In system info IT says that Y is interlocked . Also when machine is turned on ,the table is moving up like it was preparing for the pallet swap. Any help would be appriciated.
  7. #27
    Dec 2009
    546
    Quote Originally Posted by Muciek View Post
    Hello,
    You are going to have to home the APC - first. Did you try the APC home button? If That's still stuck you will have to use the Mainteance codes to get everything back in place
    John
    Sent from my SM-G930V using Tapatalk
  8. #28
    Nov 2012
    14
    Quote Originally Posted by shas595 View Post
    Hello,
    John
    Hmm, I didn't saw a button like that on the control panel here are pictures of the control panel
    Attachment 385688
    When I try codes for pallet clamp M90x it does nothing, but says that I need to reference axis before or referencing was incomplete (I can do the Z and the X). I didn't tried the M998 and M999 codes for mainteance, will that work without the referencing 1st? Is there any combination to "cancel" that pallet change during the machine boot?
  9. #29
    Dec 2009
    546
    The APC origin button is on the smaller panel on the APC side of the machine. Yes the M998 will work, if it doesn't you can open the control cabinet and there is a hard switch to force maintenance mode on
    John
  10. #30
    Nov 2012
    14
    John
    Here's the APC panel photo, only those buttonsClick image for larger version.
ID:	385690 , I will try the M998 code and report.
    EDIT:
    I tried the M998 and M999 but is does say that referencing is incomplete. I looks like I will have to disassemble that panel and look for that switch.I will do that tomorrow. Then what should I do?
  11. #31
    Nov 2012
    14
    John
    Than You very much John, I found the switch and corrected it with M codes. I have one more question, is it normal that the machine does have the Y axis + towards the operator( Y+ south, Y- north) , we bought it recently and I get hang on with it.
  12. #32
    Dec 2009
    546
    Glad you got it working.
    Yes that is normal for the Y+/home to be towards the operator
  13. #33
    Nov 2012
    14
    Is there a way to expand somehow memory on this controller (lambda 10 vm50 machine, but on motherboard IT says vm40) ?, Right now it does have 1000m of memory which is roughly 400kb.I tried running program straight from the pc by rs232(tape option) but its cannot transfer fast enough to have fluid motion od machine. On menu it says that dnc od not valid, can this be activated?
    Wysłane z mojego Redmi 4A przy użyciu Tapatalka
  14. #34
    Mar 2018
    Hello John
    I work for a company that has 6 Hitachi-Seiki HG400III's and several lathes. Our HG's are all ageing and in definite need of repair and our sources of service are becoming few. Do you have experience with HG's? Where are you hailing from?
  15. #35
    Mar 2018
    hola
    necesito manual de maquina seiki vm40 vertical machining
    Hello
    I need manual seiki vm40 machine vertical machining
  16. #36
    Nov 2012
    14
    Recently I have encountered a problem with rs232 communication , I was able to send files from machine to pc but not other way. To Fix the communication I have resoldered new mc1488 and mc1489 on pc motherboard near rs port. After taking the chips and measuring them one was corrupted. It was 98 machine with 97 computer they were SMD
  17. #37
    Dec 2009
    546
    Hello
    I am about 5 min from you from the looks of it! Send me a PM with your contact info and Ill message you
    John
    Quote Originally Posted by richlaw View Post
    Hello John
  18. #38
    Apr 2018
    Hi, I have just purchased a HC630 with Fanuc 15M and Micon16-ii. The sequencer battery was flat and I changed that and cleared the error but still had a SUM CHECK error. The ladder that displays is not as shown in my manual so we think the ladder must have been lost in the memory that was powered by the discharged battery. Subsequently when trying to investigate the ladder was in ladder mode and switched the switch on the bottom of the Micon16 card. When I switched it back the display changed and now shows what looks like a listing of the registers in the CPU and an * prompt. This reminds me of the low level command screens of microprocessor operating systems I used to work with in my Z80 days.
    Can you help with the commands to get the controller back up and then advice on how to get the correct ladder loaded in?
    Was there ever a manual for repair of the Micron16-ii?
  19. #39
    Apr 2018
    We have hitachi seiki HC400, the problem is A,B phase table alarm. Could you help us? what must we do?
    All,
    I have decided after many requests to start doing on-site service locally (in the New England area). I can be contacted via email (PM me with info) and respond very quickly, and if the problems get more intricate, I can offer help by phone. If that doesn't help then I can make the trips. I have been servicing these machines for many years and are familiar with the i80, MX3, LX3, Seicos II & III, Micon II & III, Sigma 16, 18 & 21, Fanuc RC4/RB6 (and many other Fanuc based), J300 and the very fun Lambda 10L/40L controls. I have many parts available as well as software (ladders, EPROM programs, parameters) to help you out in any situation. Contact me anytime; I have helped many many people get their machines up and running both in the US and abroad.
    John
  20. #40
    Dec 2009
    546
    Quote Originally Posted by pjhindin View Post
    Hello
    Send me a PM with you email and ill help you out
    John
Page 2 of 10 1234
  1. Hitachi Seiki Service and Support!!!!!!!!1
    By Hitachi_man in forum Uncategorised MetalWorking Machines
    Last Post: 01-31-2024, 12:29 PM
  2. Hitachi Seiki Electronic Repair
    By controlsgadgets in forum News Announcements
    Last Post: 03-14-2022, 12:02 PM
  3. Hitachi Seiki Gearbox Repair
    By DPGE Rebuilds in forum News Announcements
    Last Post: 06-13-2006, 10:49 AM
  4. Hitachi Seiki Gearbox Repair
    By DPGE Rebuilds in forum MetalWork Discussion
