Re: Part zero sensing marco
I know this is an old post but is I4 a reference to input 4? If so I assume I can change it to 7 if that is the pin I am using?
Originally Posted by
tony978
problem solved !!! here is a sample for flashcut users and I add a comparison to mach 3 . I didn't add the messages to my code for if the line in is tripped already
flashcut way to find inside center . if you use this code you need to set user variables .
(find x center)
g31 x2 I4 s1 E0 f5 (refer to user manual for info on g31 setup )
g92x0.0
g04 p1
g31 x-2 I4 s1 E0 f5
#x1 = #program.x
#xc1 = #x1 / 2
g04 p1
g1 x#xc1 f5
(find y center)
g31 y2 I4 s1 E0 f5
g92y0.0
g04 p1
g31 y-2 I4 s1 E0 f5
#y1 = #program.x
#yc1 = #y1 / 2
g04 p1
g1 y#yc1 f5
_______________________________
mach3 way Rem VBScript To center probe inside a pipe
If GetOemLed (825) <> 0 Then 'Check to see if the probe is already grounded or faulty
Code "(Probe plate is grounded, check connection and try again)"
Else
FeedCurrent = GetOemDRO(818) 'Get the current settings
XCurrent = GetDro(0)
YCurrent = GetDro(1)
Code "G4 P1" 'Pause 1 second to give time to position probe plate
Code "F4" 'slow feed rate to 4 ipm
Rem Probe Left
XNew = Xcurrent - 3 'probe 3 inches to left
Code "G31 X" &XNew
While IsMoving() 'wait for the move to finish
Wend
XPos1 = GetVar(2000) 'get the probe touch location
Code "G0 X" &XCurrent 'rapid move back to start point
Rem Probe Right
XNew = XCurrent + 3 'probe 3 inches to right
Code "G31 X" &XNew
While IsMoving()
Wend
XPos2 = GetVar(2000)
XCenter = (XPos1 + XPos2) / 2 'center is midway between XPos1 and XPos2
Code "G0 X" &XCenter 'rapid move to the x center location
While IsMoving ()
Wend
Call SetDro (0,0.000)
Code "G4 P0.25"
Rem Probe up
YNew = YCurrent + 3
Code "G31 Y" &YNew
While IsMoving()
Wend
YPos1 = GetVar(2001)
Code "G0 Y" &YCurrent
Rem Probe down
YNew = YCurrent - 3
Code "G31 Y" &YNew
While IsMoving()
Wend
YPos2 = GetVar(2001)
YCenter = (YPos1 + YPos2) / 2
Rem move To the center
Code "G0 Y" &YCenter
While IsMoving ()
Wend
Call SetDro (1,0.000)
Code "G4 P0.25"
Code "F" &FeedCurrent 'restore starting feed rate
End If
A lazy man does it twice.
