587,997 active members*
1,944 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > Monitor and Air drawbar - last two small issues
Results 1 to 6 of 6
    Jul 2006
    130
    So I have 2 annoyances I'd like to take care of.
    1) I'm not sure the formal name of the piece but the air tool mounted on the machine head that's used during tool changes leaks only when a tool is installed. Its slow enough I'm not stopped by it but its the last air leak and I'd like to kill it.
    2) the monitor has taken to flickering horribly. Horizontally with the image jumping up and down. I'm old enough to know that wacking the side of the box might fix it, but not old enough to want to mess with a CRT internals without assistance.
    Jul 2006
    130
    Re: Monitor and Air drawbar - last two small issues
    I take back the only when a too is loaded. Just quieter for a while unloaded
    Jul 2006
    130
    I ran into this article on troubleshooting crts. Nothing crazy detailed but it gave me some hints.
    http://jestineyong.com/picture-shaking-problem/
    While I haven't found the bad connection itself I gave an short term solution that eliminated the problem 90%.
    A non conductive wedge pushing up on one corner of the horizontal pcb behind the crt.
    Jul 2010
    548
    Hi Yugami, On most Milltronics machines the drawbar has a "blow off" when the drawbar is enabled. This allows air to "blow out" and coolant and chips that might have gotten into the spindle taper. Is this what is happening??
    On the CRT side of the house. call me for an LCD update or Mount an external LCD display on the front panel area. Fixing a CRT can be expensive and they don't stay fixed.
    sportybob
    53
    Sportybob, what type of LCD update do you offer? I have an older Partner VI the the LCD just went out on. Looks like the backlight is out, an ideas?
    Jul 2010
    548
    Hi Gaswiz, It will depend on what LCD you have. some kind of PC monitor mounted to the front of the panel. A Milltronics LCD update.??
    I will assume you have a Milltronics LCD.
    This is a 3 piece system., The display, the analog to digital board (A/D) and a back light inverter board. The 12VDC for the system is picked up from the J2 plug on the key board encoder card. It has a yellow and black wires going to the A/D board. On early LCD the A/D board also supplied the 12VDC to the back light inverter. on later systems the 12 VDC was picked up from the keyboard encoder card plug, (J2) had 2 pares of 12 VDC wires, one pair going to power the A/D board and one pair going to the back light inverter board.
    Shine a flash light into the display at an angle and look for an image. it will be faint. if you have a display then check if there is 12VDC going to the inverter board. If you have an early LCD there is a relay on the A/D board that turns on and supplies the 12VDC.
    If you do not have an image, connect an external monitor and see if you have a display, no display = no video out from the control.
    I do have some Milltronics LCD parts available. I also have my industrial LCD kit available.
    You can PM me or call 952-288-6340 for more info
    sportybob
  1. EZ Vision Monitor issues
    By RacerJoe in forum Bridgeport / Hardinge Mills
    Last Post: 10-14-2018, 04:15 PM
  2. OKK VM76R Drawbar issues
    By Beek in forum OKK
    Last Post: 04-26-2016, 08:46 PM
  3. Having issues with my TTS & Power Drawbar
    By mooreaa in forum Tormach Personal CNC Mill
    Last Post: 12-04-2011, 03:00 AM
  4. Arrow 500 Control Technologies Monitor Issues
    By Slick27 in forum Cincinnati CNC
    Last Post: 09-26-2011, 04:54 AM
  5. Series 2 Interact 4 Drawbar issues
    By UKRobotics in forum Bridgeport / Hardinge Mills
    Last Post: 05-20-2009, 02:46 PM
