587,671 active members*
3,470 visitors online*
Results 1 to 8 of 8
    Sep 2011
    21
    help plz on spindle
    oky my spindle has the 1/4" shank will not let me put a 1/2" shank in to use for cutting.... plz some one help me ..
    Apr 2004
    5750
    Re: help plz on spindle
    The reason it only accepts 1/4" tools is probably because it doesn't have enough torque for 1/2" ones. If you need to run 1/2" diameter tooling, get a bigger spindle.
    Andrew Werby
    Website
    Sep 2011
    21
    oky ty sir
    Nov 2011
    51
    Quote Originally Posted by gibson22 View Post
    More info needed. What kind of spindle do you have? for example if you have a 2.2Kw with an ER 20 then you can accept half inch bits you will have to get an ER20 1/2'' collet
    Sep 2011
    21
    i have this cheapo
    CNC Spindle Motor 400W ER11 & Mach3 PWM Speed Controller + Mount Engraving Kit would like to put bigger size bits in other than a 1/4 .....and my machine is the openbuild ox from mark crew but i extended it to 1500 x 1500...Click image for larger version.
    Nov 2011
    51
    i have this cheapo
    ER11 only will accept a max tool shank size of .276 or 7mm. You will need to either find some larger bits with quarter inch shafts which i really dont recommend or get you a new spindle that's at least ER20 so you can hold 1/2 inch shaft tools
    You need a ER20: you can use 1/16", 3/32", 1/8", 3/16", 7/32", 1/4", 5/16", 11/32", 3/8", 13/32", 7/16", 1/2"
    Sep 2011
    21
    thats why i want the ER20 so i can put different size bits in and some one told me that will be to heavy i was looking into one looking for options looking at hitachi routor
    https://www.ebay.com/itm/Hitachi-M12...4AAOSw8K5aubRz it dose the 1/4" to 1/2" bit sizes weight is like 7.5 lbs
  1. Replies: 3
    Last Post: 10-19-2018, 05:12 PM
  2. Replies: 35
    Last Post: 03-21-2017, 02:29 PM
  3. Replies: 39
    Last Post: 01-09-2017, 06:26 AM
  4. Replies: 5
    Last Post: 07-19-2013, 05:16 AM
  5. mach3 spindle dro not working, spindle speed changing while jogging and running code
    By jasminder in forum Mach Software (ArtSoft software)
    Last Post: 02-23-2011, 07:12 AM
