a plugin for mach3 to have possibility to make 5 axis milling
Videos | Mach3FiveAxis
thanks
thanks
is it possibile to buy this plug in.
thanks
Thank you for your interest and sorry for the delay.
Yes, you will be able to buy it. You are interested by what version, A/C table-table or B/C head ?
For both versions, news options like choosing between Real-time simulation or software simulation (faster), the display of the toolpath, greater size of the workpiece ans other small things.
For the B/C head management of RTCP G43.4 / G49.
Thanks.
Mach3 already offers 6-axis simultaneious milling.
What is extra here?
Cheers
Roger
Mach3 5 axis plugin for A/C rotative table is now available,
Tutorial is in progress, so be careful, do not machining in real mode if you are not sure of you.
Mon site | Un site utilisant WordPress
Best regards,
Richard
I already do 4 axis machining as a matter of course. I am quite sure I could do 5 axis machining with Mach3 with no add-ons
So what does your plug-in offer?
Cheers
Roger
Yes you could, i did it too before, i used mastercam to do 5 axis machining, until my boss purchased the dmu75 monoblock. Because whitout any cam software, mach3 can't do 5 axis machining. Now with this plugin, for example, you can program and create your gcode easily and manually. With a probe you can place your block anywhere on the table and that you can't do, even with any cam sofware and other things again. If you already have machined on a machine like a dmu75 you could understand what i am talking about.
Best regards
That is just not true.
Maybe what you mean is that it is very hard to create the code for 5-axis machining without CAM? That I could understand. But Mach3 itself can do 5 or 6 axis machining all by itself, IF you have the code for it.
I create my 4-axis code by hand using mathematics. This works fine. That lets me design some things but not everything. The same would apply for 5-axis code.
Cheers
Roger
Sorry for the delay, but a error took me a long time to solve the problem. I think freeze for a few people or impossibility of executing the Plugin.
Now it's ok and demo version have been updated and will be available this night.
At the same time, the full version will be too available for people want to buy it.
Some videos of full version:
tuto:
https://youtu.be/1wN_AEV8S_U
Virtual machine:
https://youtu.be/mEcfTHgkahU
https://youtu.be/fbIYUa2Dojg
https://youtu.be/SGB0buJYfhs
x64 compatibility:
https://youtu.be/og_hrhaHDgQ
Full version gives you the possibility to create your own virtual machine.
Best regards,
Richard.
http://motion5x.fr
Shop is open
Have fun!
Best regards,
Richard
Some feedback for you.
The pricing on the shop page has a corrupt format. Just have a look.
You need to test the SW under V0.062 as well as that is the most trusted version (NOT v0.066).
Can it drive an ESS? That is the most common external pulse engine.
Can it handle different tool shapes, such as T-slot cutters, ball-end cutters and dovetail cutters?
Cheers
Roger
Thank you!
Price format is Euro, What can you see ?
I just tested with a USB controller (UC100) and LPT port, not tested with others but i think it work. People can download and test it the demo version and make me a feedback for differents driver and differents version of mach3.
Yes it can handle different tool shapes, cylindrical, ball-end cutters and dovetail cutters. T-slot cutters is not implemented yet ( that is to say "yes" and "not") but easy to add it.
English version, something like
Price
249
00
e
Cheers
Roger
Indeed, it's ok now
thanks,
Richard
Tested with Mach3 R 3.043.062, it'ok
How to create and configure a virtual machine
Machine VirtuelleMotion5x | Mon site
https://youtu.be/gMN2TAn5pIs
Thanks,
Richard
For people using a laptop with 2 graphics cards, Nvidia + Intel-HD
How to fix the problem
https://youtu.be/-TGvkCmYZHQ
for people download the demo version, if you run this plugin on a windows x64 and you get a crash (this plugin do not run on a windows x64) , this is the procedure to solve it :
Best regards,
Richard.
buongiorno, vorrei chiedere se è possibile scaricare il plug-in in questione e dove lo si trova... grazie mille
