Re: Low speed spindle motor / gearbox selection
Originally Posted by
ZeroBacklash
How about a Automation Direct VFD GS3 series with encoder connected to a 3phase motor. Will this give sufficient accuracy to do position control?
My torque requirements are minimum 100Nm.
Unfortunately DMM servo's are not meeting that They have max torque of around 12Nm.
Unfortunately no, I have a GS3 and encoder on the 7KW spindle motor on my lathe. I thought I might be able to get it to position, but the GS3 is just too ''loose'' to make that work, I played with it for days trying to make it work. When I can find one at my price, I'm going to replace the spindle motor with a 10KW servo.
Since you only need 10 rpm, a 10:1 gearbox would give you 120Nm, to be really safe go with a 15:1 gearbox and you would have 180Nm available.
Jim Dawson
Sandy, Oregon, USA
