588,636 active members*
5,978 visitors online*
Results 1 to 4 of 4
    Jan 2005
    Spindle Motor Selection
    Hi All,
    Is there any spindle motors avaliable that has the capability of both low speed (for metal) and high speed (for wood)? Or is it best to have 2 motors? The plans that I am looking at calls for a 3 to 3 1/2 hp motor.
    Any sugestions?
    Thanks, Walt
    Mar 2003
    35538
    When you say metal, do you mean steel? Or non-ferrous metals? If you don't need to cut steels, a 3HP variable speed router can usually slow down to around 10K rpm, and you can get router bits made specifically for aluminum that work at those and higher speeds.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Jan 2005
    Gerry,
    Are you talking about an off the shelf router like Porter Cable or are there other types of spindle motors that are capable of these wide ranges of speeds?
    Walt
    Mar 2003
    35538
    Yes, a PC 7518 has 5 speeds, from 10K to 22K or so. An 892 has continuosly variable speed. Just about any other option will set you back a few thousand dollars. There are a lot of discussions in some of the other forums about spindles.
    Gerry
  1. Sherline spindle to 30k RPM -- am I crazy?
    By nicad in forum Uncategorised MetalWorking Machines
    Last Post: 11-17-2010, 09:57 PM
  2. CNC Controlled Spindle motor speed control
    By gregmary in forum CNC Machine Related Electronics
    Last Post: 02-28-2009, 02:01 AM
  3. Mill spindle repair?
    By kong in forum Uncategorised MetalWorking Machines
    Last Post: 04-02-2005, 07:01 PM
  4. Gilman box spindle pics
    By Swede in forum Benchtop Machines
    Last Post: 03-30-2005, 04:41 PM
  5. 2.2KW Allen Brad. Spindle motor?
    By GalaticDan in forum Servo Motors / Drives
    Last Post: 02-02-2005, 06:46 PM
