603,796 active members*
2,791 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Getting the 179 alarm on Haas VF2
Results 1 to 10 of 10
    May 2016
    19
    Getting the 179 alarm. Filled with oil still alarmed out. I jumped the switch wires and it runs fine. Question is where can I get this switch? It looks like the oil pressure switch on my old Jeep. Any part numbers or do I need to order from Haas?
    Oct 2011
    106
    Re: Getting the 179 alarm on Haas VF2
    Go to the Haas website and you can put in your machine serial number and it will come up with all spare parts for your machine. It’ll give you a price too. At least you’ll know what part you are looking for if you decide to get it elsewhere and a ball park for the price.
    May 2016
    19
    It just occurred to me that possibly just jumping the switch is not solving the problem. Although I can see air bubbles moving in the line when I jump the switch.
    DJM, I just looked it up, looks like thy want $75 for a $3 oil pressure switch out of a Jeep. Wonder if anything is special about this switch?
    Mar 2010
    1852
    Yes, that switch should work. Just like the pressure switch for the lube system in the rear, just a $3.00 switch from NAPA.
    Mike
    Two Haas VF-2's, Haas HA5C, Haas HRT-9, Hardinge CHNC 1, Bother HS-300 Wire EDM, BobCAD V23, BobCAD V28
    May 2016
    19
    mike, from what I have learned this is a 1-2 psi switch which must be so because the oil runs out of a overfill hole when it's full so there can't be much pressure there. More or less a circulator maybe.Would you know of a part number? Thanks
    Mar 2010
    1852
    You are talking about the reservoir or tank, there would be no pressure there. I'm not sure what the pressure is, but try a simple ford oil pressure switch.
    Mike
    May 2016
    19
    Okay, took the spindle cover off and removed the pump and found the gear that runs the pump ids toast. Have one ordered from McMaster. Also while inside there I found my Z axis ball screw is dry. Shouldn't that be oily?
    Nov 2007
    479
    Quote Originally Posted by specialty8 View Post
    Not dripping with oil, to much oil is not a good thing either. It could be dry way up top where the ball nut never comes in contact.
    Sep 2010
    32
    Any one have any luck finding a pressure switch other than from HAAS?
    Mar 2010
    1852
    Quote Originally Posted by manike View Post
    Take it to any auto parts store.
  1. haas alarm 153
    By djmachineshop in forum Haas Mills
    Last Post: 08-14-2016, 08:19 PM
  2. ALARM shuttle drawbar alarm haas
    By timmydabull in forum Haas Mills
    Last Post: 02-18-2013, 07:47 PM
  3. Haas VF6/50 Alarm 961
    By BJSwart in forum Haas Mills
    Last Post: 01-09-2012, 05:57 PM
  4. Haas Alarm 161 - Help!
    By Guitarrero in forum Haas Mills
    Last Post: 05-13-2009, 04:55 PM
  5. Haas VF2 ALARM 127 &115
    By grease in forum Haas Mills
    Last Post: 10-18-2007, 09:31 PM
