Is there enough InfraRed from LED's to do it?
Do you have any bright sunlight there?
I picked up a nice e-prom eraser on ebay sometime ago.
Al.
Al.
Albert E.
I think there are some. After a few hours it starting to show errors when I verified it but it’s going to take ages. I’m looking for a eprom eraser from eBay but it will take a long time to order also.. I got some extra chips on their way from China so I can flash it onto new ones if I don’t manage to erase this one first.
We don’t have long days here in Norway in the winter so it’s limited time with sun. I might take my first solarium ever tomorrow just to erase this chip lol
edit, I’ve just read that welding arcs has a lot of UVC in them. Can I clear it by having it close to me just welding some to give UVC light for the chip?
I always understood that you needed UV light to erase an Eprom not InfraRed
I know this is a old thread but it sparked my interest. So how did the ladder get changed. Was it the fanuc editing software or something simpler. I used to mess around with gm fuel injection programming which was Eprom based. It was a cycle of ease with uv and then burn the new image. Is there some software readily available to read ladder logic from a eprom and then edit it?
Scott
There is a memory upggrade available for the various 0 controls.
The 0-C control needs a PMC-ram board to change the ladder and can store the ladder in that card. We have one, but it is not for sale. Then you can burn the ladder into eproms with another card.
Sorry for the late reply. The short answer is that I bought a eeprom reader, read out the chips I had, then I downloaded a dosbox emulator and changed the code in FLADDER adding the G127.5 line and tied it to a input I could wire a switch to. Works perfect. The only issue is that the ladder is written over two eeproms so you need fanuc hardware to split it before/after code change. I got help from a forum member here that I sent the two .BIN eeprom files to and then he combined it into a readable file for FLADDER so I could change my code. I then sent it to him again so he could split it into two EEPROM files and I wrote them back to two wiped EEPROMS. It's not very hard to do but you need som basic knowledge about this or take your time reading up on it. Splitting/Combining the .BIN files can only be done with fanuc hardware to my knowledge so you either need the PMC-ram board memoryman mentions or something similar (there are two ways of doing it but I don't recall the last one now).
