Originally Posted by
Dtcrafts
hi
that is the same set up as our 130w machine and I can't find a fuse any where
so I would first go for a switch
you say the power is coming into the machine ok from there it will go to the emergency stop switch so is there voltage going in to the ES if so is it actually coming back out
( it is not uncommon for the ES to burn out inside) if there is no power there is often a second set of terminals on them that you can use, I f it is coming out of the ES it will then go to the on/off
switch so with the switch open is the voltage coming out, try these first to eliminate them
Dave
