Hello,
So i had a collision on a piece of metal and damaged a bearing of my es919.
New shaft costs 4100,- from hsd Italy and a brand New spindle 6500,- euro from hsd Italy.
Made the choice to buy an New spindle so i can repair the old shaft with New bearing and keep that so i can Quick change the spindle when neeeded.
I think you have used the wrong bearings or the shaft is bend.
Abec 5 is way to low for these high speeds.
The bearings for this spindle are made in germany by Gmn.
These are Abec 7
https://www.gmn.de/suche/?bereich=kugellager
Search for:
HY KH 6008 C TA
HY KH 6006 C TA
I got this info from hsspindles.com
So Hope this info is of any use for you or someone.
Now in return can you tell me how to remove the drawbar?
