Ok I did find a blown fuse, its was one of the small glass fuses on behind the main board. The one marked S in this pic.
I replace the fuse then either R or S fuse blows.
Any ideas where the short might be?
Also with both fuses removed. the top two wires have continuity across each other, Not sure if they should? Even with the capacitor removed still show continuity
