603,975 active members*
3,308 visitors online*
IndustryArena Forum > CAD Software > Autodesk > Stupid Question - How to center objects on top of each other
Results 1 to 8 of 8
Go4Long Stupid Question - How to... 12-09-2018, 04:52 AM
ger21 Re: Stupid Question - How to... 12-09-2018, 01:28 PM
Go4Long Re: Stupid Question - How to... 12-10-2018, 08:06 AM
deadlykitten Re: Stupid Question - How to... 09-01-2023, 01:12 PM
Jimmy49548 Re: Stupid Question - How to... 08-31-2023, 01:04 PM
Superman Re: Stupid Question - How to... 09-01-2023, 01:25 PM
KarsonCurtis Re: Stupid Question - How to... 10-30-2023, 05:55 AM
KarsonCurtis Re: Stupid Question - How to... 10-31-2023, 08:42 AM
    Dec 2018
    This is going to seem like a stupid question I'm sure, but I've tried to watch videos and everything and just can't seem to find the answer to this. I'm trying to put together a model for a base plate for a camcorder to attach to a bracket that I already have. It will consist of 3 rectangles of decreasing size, with a threaded hole on the bottom and a stud on top.
    I've mocked it up in Photoshop (because that I actually understand how to use), but I just can't get the blocks to anchor themselves to the center point of the shape below in fusion.
    This is my first foray into 3d modelling, so be gentle. Was thinking of rounding the corners of the various bits as well. not sure how much work that would be to do.
    Anyway, any help would be appreciated.
    35494
    Re: Stupid Question - How to center objects on top of each other
    The simplest way is to model them in place.
    Start with the main "box"
    For the next "box", create a new sketch on the face of the first one, and draw a rectangle. Dimension the rectangle relative to the edges of the first "box". When centered, extrude it to the correct height.
    Repeat.
    To round the corners, use the Filet command from the Modify menu.
    Dec 2018
    I think I MIGHT have been successfulish.
    Attached Thumbnails Attached Thumbnails Screen Shot 2018-12-10 at 12.06.05 AM.png
    Jun 2015
    4191
    i thought you needed in machine alignment sugestion for cam modeling, well, is easy
    there are tools that allow to draw a rectangle from it's center/gravity point, thus, with such a tool, you simply draw 3 rectangles, by always selecting the origin as the 1st point
    you know what i mean ? i can share later a pick from solidworks, if you wish / kindly
    Apr 2021
    46
    You can draw a diagonal on them and line up their midpoints
    Dec 2008
    3216
    5 year old post.. .
    If he hasn't done it by now, I'd have sacked him.
    Oct 2023
    I think it can be done.
    Oct 2023
    I think you can do it. If you are stressed and tired, try coloring pictures to help you reduce the Coloring combo pressure to continue working.
  1. Newby Question - overlapping objects in RDCAM v8
    By demsley in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-03-2017, 05:53 PM
  2. sorry.. stupid question
    By newguy1985 in forum DIY CNC Router Table Machines
    Last Post: 07-01-2012, 03:48 AM
  3. may be a stupid question but......
    By kaighn80 in forum Welding Brazing Soldering Sealing
    Last Post: 03-30-2012, 02:59 AM
  4. This might be a very stupid question.
    By phacer in forum Fanuc
    Last Post: 10-27-2010, 01:25 PM
  5. Stupid Question
    By CNCRob in forum Community Club House
    Last Post: 09-04-2005, 07:42 PM
