587,480 active members*
3,229 visitors online*
Results 1 to 9 of 9
    Dec 2017
    47
    Laser Pulse control
    Installed a 15 watt laser on my engraver. Laser works fine in stand-alone mode but cannot control pulse on\off with my controller. I assume the TTL plug-in is what
    controls the pulse? Using a Keyestudio rev 0.9 with GRBL. Any help greatly appreciated!
    Aug 2014
    125
    Re: Laser Pulse control
    Really not enough information to go on to give an answer.
    Dec 2017
    47
    This is how I have it hooked up. Shouldn't the input marked laser control, control the laser pulse?
    Aug 2014
    125
    Have you configured grbl to enable laser?
    Dec 2017
    47
    How would I do that, thanx
    Aug 2014
    125
    Do some research. It’s well documented
    Dec 2017
    47
    Thanks soooooooooo much for your help.
    Aug 2014
    125
    You’re welcome. It’s always gratifying to see people making the effort and not just sitting back and wanting to be spoon-fed.
    Thats how I learned. It has paid off, handsomely.
    And FYI, the most powerful diode laser made is ~6.5W, so you were ripped off with your ‘15W’ unit. It’s an over-volted 6W unit. You’ll be lucky if it lasts 200 hours.
    Here, as I’m feeling generous: https://github.com/gnea/grbl/wiki/Grbl-v1.1-Laser-Mode
    Just as a pro tip, I typed ‘grbl laser’ into google and it was the first entry that presented itself.
    Dec 2017
    47
    Quote Originally Posted by ledaero View Post
    Have done my research I know that $32=1 turns laser mode on and 0 turns it off. Have PWM connected to TTL output, but laser still does not turn on and off as it should, could I possibly have a defective controller for the laser?
  1. Laser setup - Mirrors aligned, getting two dots with pulse and tape on laser head
    By tjandt in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-06-2019, 01:44 PM
  2. Kflop. Spindle VFD digital control by pulse train
    By Yepez in forum Dynomotion/Kflop/Kanalog
    Last Post: 06-14-2014, 06:55 PM
  3. Spindle pulse feed back out of control
    By woffler in forum Mach Mill
    Last Post: 08-18-2011, 01:43 AM
  4. Measure CO2 laser pulse
    By Bertho in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-07-2009, 05:23 AM
  5. Spindle RPM control - Do I need an index pulse?
    By Lexx0001 in forum LinuxCNC (formerly EMC2)
    Last Post: 03-27-2009, 07:42 AM
