587,161 active members*
2,890 visitors online*
Results 1 to 14 of 14
    Mar 2010
    621
    Suggestions for echain/cable mgmt?
    I recently replaced my router with a spindle and need to come up with something to manage the power cable to the spindle due to its central location.
    I don't have a lot of slack in the cable so I'm pretty much stuck with the general position so I'm looking for some ideas or suggestions... the cable is too thick for tight radii so I had abandoned my original setup.
    Attachment 413300
    Attachment 413302
    Adam,
    Gecko G540, Rack and Pinion Drives-X and A axis, 1/2-10 5 Start Acme-Z Axis
    4-THK HSR 25 Linear Slides, KL23H2100-35-4B, Power Supply-KL-600-48 48V
    May 2005
    3920
    Re: Suggestions for echain/cable mgmt?
    This sucks as I’m getting invalid attachments.
    Given that I really don’t know the specifics here you have basically two choices. One is a drag chain. The other is the use of flexible electrical tubing. It is good that you are concerned about bend radius but not having enough cable works against a robust install. You may very we’ll end up needing a new cable to install these options properly.
    Flexible electrical tubing suitable for CNC work generally has a larger bend radius than a drag chain. This requires more thought into how it is installed. More so you really want to stay away from the minimal radius. However if an arraingement can be found the minimizes bends and is of modest travel ( think Z axis here) you can get good long lasting protection for your cables.
    Drag chains, especially the “open” ones, have the negative aspect of collecting junk or searching. This junk can accelerate cable wear. However on relatively long axis you don’t have much of a choice. A totally enclosed drag chain adds a bit of cost. The bend radius on drag chains is basically a hard parameter. Thus you need to design around the specific chain you select or get premature wear or breakage.
    Unless the drag chains are designed for clean rooms you get a lot of particulate matter coming off the chains and cables as they wear. In some cases I’ve seen designers resort to using large diameter urethane tubing to support cabling in a clean room. The problem is this isn’t self supporting.
    Mar 2010
    621
    Thanks for the reply Wizard.
    [QUOTE]Flexible electrical tubing[/QUOTE
    Are you referring to a PVC type product, similar to this?
    https://www.controleng.com/articles/...-applications/
    Is PVC conduit rated for continuous movement that a CNC would generate?
    I believe the biggest problem I have is the "Self supportive" properties of echain that I'd be missing...
    Adam.
    15362
    Quote Originally Posted by adam_m View Post
    Attachment 413300
    Attachment 413302
    Adam,
    If you have the wrong cable that does not have a flex rating then you will have to change it as it won't last very long if it does not have a flex rating, your attachments don't work
    What Kw is your spindle??? I will give you the correct cable spec's you need for your Spindle
    No you can not use the PVC Conduit for anything that has movement
    Mactec54
    15362
    [QUOTE=adam_m;2267142]Thanks for the reply Wizard.
    Adam.
    No that PVC Conduit you posted is only good for stationary installs
    You can use this PMA Tubing but will need some supports
    Mactec54
    Oct 2009
    815
    mactec54, is that a slit conduit? From what I can see, it looks closed. Would be a pain to modify anything later on.
    15362
    Quote Originally Posted by davida1234 View Post
    No they are closed is what you would want it to be, you can get it with a slit, but for this use you would want it closed they have all the mounting hardware for this PMAFLEX as well
    You can also slit it your self if you had a need
    Attached Thumbnails Attached Thumbnails PMA.pdf
    Mactec54
    Mar 2010
    621
    Thanks for the posts.
    I've got Igus 14/4 cable and a 3.5KW spindle.
    I've not heard of PMA tubing off to do some research...
    What are you referring to when you mean "but will need some supports"? I assume unlike echain its not self supporting... how do people deal with supporting wires when there is nothing to hang from?
    15362
    IGUS sells it , for supporting they have many kinds of fittings you could use, they have snap clamps that fit the conduit, that you use to support it where needed
    Attached Thumbnails Attached Thumbnails VND-M207GT Coupling.PNG   BVH-1700 Support Clamp.PNG
    Mactec54
    May 2005
    3920
    No not at all, you will want to avoid all flexible conduit that is designed for static installations. Something similar to this: International Metal Hose - Flexible Conduit, Tubing and Hose might be worth looking into. The tubing should be marketed for dynamic usage in CNC machines.
    Well the one linked isn’t. Most of the tubing I’ve seen that is rated for CNC usage isn’t PVC.
    Adam.
    That self supporting quality of drag chain makes it the best choice for your long axis. Flexible conduit will work in the shorter areas of a machine like the Z axis. Just because it isn’t self supporting (compared to drag chain) doesn’t mean it isn’t stiff.
    There is no perfect cable management system. I through out the flexible conduit idea because there are some advantages along with disadvantages.
    May 2005
    3920
    [QUOTE=mactec54;2267406]
    This is something that is very important to understand for people new to these products. There are many flexible conduit solutions out there that are never intended to be used dynamically on CNC systems. In some cases these products wouldn’t last an hour on even a modest CNC.
    It is very important to buy systems that are actually rated for the work load.
    I might suggest that tubing is best used where you can get away without supports. Short excursion axis like the Z may be serviced with a tubing solution anchored at both ends. You might as well forget about such tubing on a long X axis unless you can mechanically guide it.
    The big advantage with tubing in my mind is that it is a cheap way to protect wiring 100% from swarf chips. At least compared to a sealed drag chain.
    Feb 2009
    6028
    This is pretty nice, but a little spendy
    https://www.igus.com/info/energy-cha...advantages-com
    Mar 2010
    621
    So I ultimately just stuck with e-chain since I had it at my disposal and it seems to be doing what it's designed for.
    I fabricated an angular bracket for my Z axis and ultimately will attach it at the spindle end - but for now it seems to be adding some rigidity to the cable. I also cut the Z motor mount to avoid any potential issues with it as well.
    Appreciated all the suggestions.
    Adam,
    I made one. Inexpensive and works well.
    DIY Cable Carrier Tray - WoodWorkerB
    WoodWorkerB
    HobbyCNC.com, WoodWorkerB.com
  1. "Cable Chain Suggestions/Ideas"
    By atomarc in forum Benchtop Machines
    Last Post: 04-25-2017, 03:26 PM
  2. Finished my new Echain project
    By msimpson99 in forum DIY CNC Router Table Machines
    Last Post: 02-16-2012, 09:32 AM
  3. DIY flex metal echain
    By mlaws1172 in forum DIY CNC Router Table Machines
    Last Post: 07-24-2009, 08:52 PM
  4. Helpful Info on Coolant Selection & Mgmt
    By dkaustin in forum Tormach Personal CNC Mill
    Last Post: 06-03-2008, 06:34 PM
