Thanks peter, that totally makes sens. I am trying to build a machine because
1. it's much more convenient to have my own machine
2. I can do stupid things on it without being yelled at
3. I will convert it into a 3D printer and laser cutter with some inexpensive modifications.
4. It's dope and I will learn a lot in the process
I redesigned it to use mostly solid 1" steel plates (they aren't toooo expensive if I keep it small) and significantly reduced the work volume down to about 18"(y)x 12"(z). Using my FEA solver, I get about 2/10th deflection under 150 lbs or a little over 3 thou at 1 tonne on the gantry in both x and y directions(add about 2 thou at 1 tonne if I include the entire frame assembly). The linear solver is all I have, and I believe it does a decently good job at solving systems with small deflection (correct me if I'm wrong, I am absolutely no expert in FEA). Also do you have a link of the article talking about 1 tonne tool load?
https://drive.google.com/file/d/1O1N...ew?usp=sharing
Does it look like it will work and do you spot any glaring design errors? Thanks a lot.
