Originally Posted by
awerby
I believe it can generate a heightfield mesh from a JPG; that's where it analyzes a grayscale image, placing points on a vertical scale that (usually) sends dark pixels low and light ones high. Then it constructs a mesh that connects the dots and a program that will carve the mesh. This would typically be used to create low-relief decorative effects on the surface of a form, rather than the form itself. So if you wanted, say, rattlesnake scales on your grips instead of the normal checkering, it could do that, using a high-def photo of the snakeskin. But you wouldn't use it to construct the grips themselves; you'd use CAD software for that.
