Originally Posted by
joeavaerage
modern AC servos have a programmable drive. There are a lot of parameters to set. In most cases you can set them by pushing buttons on the drive
like programming a watch, but its a real PITA and mistake prone. Most manufactures offer software assistance that resides on a PC by which you program
the drive. Once the drive is programmed to your satisfaction you can install it in your machine without the need of a PC. Programming drives with a PC is highly
recommended.
The only 2D standalone Step/Direction plasma controllers that I've had anything to do with are cheap Chinese ARM based units. One customer had several, all of them
blew up eventually and the standalone THC controllers blew up regularly. In the end I convinced him to go for Mach4, a Hicon motion controller with realtime THC
control and he hasn't looked back. Now Mach4 has a script based THC feature which as far as I'm concerned leaves those cheap and nasty ARM controllers
for dead.
As for the Fanuc/Seimens type controllers, well the sky is the limit, I hope you have plenty of money, you'll need it if you want a good industrial control.
Both. In the servodrive you will program absolute max accelerations, velocities, voltages, currents and more. Then in the controller you will have to
program desired max accelerations and velocities, at least a little less than you have programmed into the drive. It doesn't matter whether the controller
is a PC type or an industrial standalone type you will have to program it with these parameters.
Craig
