587,300 active members*
3,036 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Axis servo motor vs. Spindle servo motor
Results 1 to 4 of 4
    Jul 2005
    17
    Can someone explain the difference between axis servo motors and spindle servo motors ? When I look at the spindle servo motor brochures, they talk of laminated yoke, induction servo, etc. etc. What do these all mean ?
    I know that the spindle servo has to run at higher speeds compared to normal servos that peak at 3000/4000 rpm.
    Thanks in advance.
    Iyer
    Dec 2003
    24223
    Spindle servo motors would probably indicate that the spindle is capable of positioning for such things as tool change etc and can be anything from a high quality AC induction motor to almost any other technology, with the right controller and feedback.
    Al.
    Albert E.
    Jul 2005
    17
    Thanks, Al.
    I understand the servo part, but what I do not is this : you have motors that are called AC servo motors. And you have AC servo spindle motors ? So what is then special that is added to a normal AC servo motor to be able to qualify as "spindle" motor ? Put another way, why cannot we use the normal axis AC servo motor to drive the spindle of a machine tool ?
    Dec 2003
    24223
    To use a AC servo motor, you will need the drive suited to the motor technology, i.e. P.M. motor, either AC sinusoidal or BLDC, with AC induction motors, the spindle drive is made for this technology, an enhanced VFD if you like.
    I have used AC servo's and BLDC for a spindle, just a bit more costly.
    Al.
    Albert E.
  1. Servo motor to spindle
    By vortex in forum Vertical Mill, Lathe Project Log
    Last Post: 11-20-2011, 07:06 AM
  2. Servo motor used as spindle motor question
    By BrassBuilder in forum Servo Motors / Drives
    Last Post: 10-12-2011, 04:13 AM
  3. difference between servo motor and spindle motor
    By BobM3 in forum Servo Motors / Drives
    Last Post: 04-08-2011, 02:43 PM
  4. Servo Motor for Spindle
    By dneisler in forum Gecko Drives
    Last Post: 06-17-2008, 04:25 AM
  5. Servo motor used as spindle motor?
    By fatal-exception in forum Uncategorised MetalWorking Machines
    Last Post: 09-14-2007, 08:55 AM
