587,968 active members*
3,232 visitors online*
Thread: Concrete VMC
Page 14 of 16 41213141516
Results 261 to 280 of 305
  1. #261
    May 2016
    108
    Re: Concrete VMC
  2. #262
    May 2016
    108
    Re: Concrete VMC
    Today i machined the main shaft that is holding the plate on where the tool grippers are. I also made a small new movie with a status update on the machine. You can also see the toolchanger move.
    Stef
    https://www.youtube.com/watch?v=-_5gqej_uTU
  3. #263
    Re: Concrete VMC
    First of all, great work Stef and kudos to your persistance on a such an extensive project!
    Question:
    Saw that you prepared yourself for the 4&5th axis too. Do you intend to build it on your own? If so, what kind of mechanics do you intend to use? Harmonic drive?
    And may I ask were you anytime considering an HSK spindle and why you didn’t go for it at the end?
    P.S.
    Would love to see your project insights even more often.
    All the best,
    Aleksandar Sladic
  4. #264
    Aug 2009
    291
    Re: Concrete VMC
    That is really coming along!! Will the tool changer have an enclosure or be exposed to the coolant and flying chips?
  5. #265
    May 2016
    108
    Re: Concrete VMC
    @SladicStroj i bought that BT30 spindle already a long time ago. At that point i dint really tough about other spindles then a bt30. I still don't regret this spindle so far it works perfect.
    rocketflier Yes there will be an cover around the carousel with a door that opens when the carousel moves in.
    This weekend if finished up the last wiring en coding on the macro, made 2 videos about it one that explains the tool change process and the other one show some small machining with the use of a few tool changes.
    Stef
    https://www.youtube.com/watch?v=gf1u1gDVMTY
    https://www.youtube.com/watch?v=_Yqt3Masif8
  6. #266
    Re: Concrete VMC
    I can't believe no one has commented yet since your last update. Awesome progress! Youtube actually recommended your videos for me before I even checked your thread.
    I love your touch screen and interface, it looks fantastic. Did you do the interface work yourself?
  7. #267
    Mar 2013
    88
    Re: Concrete VMC
    Very nice, I haven’t checked in awhile. Great progress!
  8. #268
    Dec 2011
    155
    Really nice project!
    Does your vfd stop at a certain orientation? How do you set that up?
  9. #269
    Jun 2017
    7
    Re: Concrete VMC
    Hi, can you kindly tell me which model you used like Shaft Couplings?
  10. #270
    Mar 2017
    409
    Re: Concrete VMC
    Quote Originally Posted by dbsharp View Post
    He is using a servo motor for the spindle.
  11. #271
    Jan 2009
    3
    Re: Concrete VMC
    Hi Stef,
    Lovely machine. I am looking at making my own cnc as well, what size linear slides have you used on the x,y,z axis?
    Pre-loaded carriages, what rated preloading do they have??
    Many Thanks
    Ian
  12. #272
    Jan 2009
    3
    Re: Concrete VMC
    Curious also if you have cut steel on it?
  13. #273
    Re: Concrete VMC
    Great work, Stef!
    I'm a machine service tech repairman since almost 20 years, and I must say I'm very impressed by your work. Very nice indeed. I'd love to build something similar one day, this is great inspiration. Right now setting up a small 120 m2 home machine shop, but for now I'm installing old school manual milling machines and lathe. A surface grinder and a cylindrical grinder by TOS. Latest addition is a 550x350x450 VMC by aerospace machine supplier Modig Machine tools. Old school TNC150 control, my first CNC.
    Keep up the fantastic work, thumbs up to you! /Lasse
  14. #274
    Jul 2013
    Re: Concrete VMC
    Stef,
    I have just finished reading the thread from start to finish. Your attention to detail is outstanding and amazing build.
    I am/was preparing for my concrete router build but now rethinking my plans after seeing yours.
    Do you mind sharing the cost for getting the laser cut table?
    Cheers
    Dave.
  15. #275
    Dec 2008
    33
    Re: Concrete VMC
    Stef,
    Can't say enough about your build. I've done a few and this one is beautiful and inspiring, especially the creative methods to avoid shipping parts our for 3rd party finishing. I've read the entire thread, and for some reason I can't find your selection of linear rails and bearings. Would you mind providing some guidance on how you sized them and what supplier you went with?
    Cheers,
    David
  16. #276
    May 2016
    108
    Re: Concrete VMC
    Hey David,
    I selected the rails on a feeling. its not really based on a calculation. i bought them all on aliexpress at the same seller:
    https://nl.aliexpress.com/store/4373...ead_12242861.0
    Stef
  17. #277
    May 2016
    108
    Re: Concrete VMC
    Made a small video about a project im working on now. It can show you some actual machining with sound.
    https://www.youtube.com/watch?v=9tR8xnXpEs8&
  18. #278
    Jul 2018
    6499
    Re: Concrete VMC
    Hi Mckoz- David
    The rail suppliers (like Hiwin) have design manuals that lay out how to size rails and cars. They have worked examples as well.. Peter
    https://www.hiwin.com/downloads.html#manuals
  19. #279
    Mar 2013
    88
    Re: Concrete VMC
    [QUOTE=stef110;2380710]Made a small video about a project im working on now. It can show you some actual machining with sound.
    QUOTE]
    Impressive- nice work
  20. #280
    Dec 2008
    33
    Re: Concrete VMC
    Hi Mckoz- David
    Thanks for the link Pete.
  1. Using concrete as a fixture
    By GITRDUN in forum Work Fixtures / Hold-Down Solutions
    Last Post: 06-30-2015, 09:17 PM
  2. Concrete Stamp....
    By AussieGecko in forum Uncategorised MetalWorking Machines
    Last Post: 08-15-2013, 01:25 PM
  3. Replies: 0
    Last Post: 11-28-2012, 06:39 PM
  4. Concrete Lathe
    By tusavision in forum Linear and Rotary Motion
    Last Post: 01-18-2010, 01:26 AM
  5. Polymer Concrete
    By ericdwilso in forum Vertical Mill, Lathe Project Log
    Last Post: 11-13-2006, 06:22 PM
