If your turret is continually spinning I'd say your solenoid has failed.
Your machine does not use a 9000 program to control the turret
no..... sir........ turret is not continually spinning.turret follow tool number accurately ..also work in jog mode..the issue is turret not locking ..in other words motor not reverse activating to complete the tool change cycle..
turret not to reverse and not clamp so not activating diagnostics 17 bit 1..
regards
fsa
If you can see the solenoid activating and turning on 16 bit 7 check your relays
If you can see the solenoid activating and it is not change sensor
you mean if solenoid activating and turning on 16 bit 7 then i have to check relay...ok but which relay..
can not understand what do you want to say///(If you can see the solenoid activating and it is not change sensor)
There is a cover on top of unit about 65 dia take it off to see solenoid I can't remember exactly what relay I think it is top row 2nd and 3rd from right I do not have drawings in front of me
i have a wiring diagram if you say i can share with you..
and this is i confirm you that solenoid and both sensor are work fine the only thing is encoder metal ring not come under the locking control switch
Yes share I will advise when I am not at work
