587,611 active members*
4,007 visitors online*
Page 2 of 3 123
Results 21 to 40 of 54
  1. #21
    May 2016
    526
    Re: Diplomatic turret BSV-N-120
    If you can see the solenoid activating and turning on 16 bit 7 check your relays
    If you can see the solenoid activating and it is not change sensor
  2. #22
    Aug 2007
    224
    you mean if solenoid activating and turning on 16 bit 7 then i have to check relay...ok but which relay..
    can not understand what do you want to say///(If you can see the solenoid activating and it is not change sensor)
  3. #23
    May 2016
    526
    There is a cover on top of unit about 65 dia take it off to see solenoid I can't remember exactly what relay I think it is top row 2nd and 3rd from right I do not have drawings in front of me
  4. #24
    Aug 2007
    224
    i have a wiring diagram if you say i can share with you..
    and this is i confirm you that solenoid and both sensor are work fine the only thing is encoder metal ring not come under the locking control switch
  5. #25
    May 2016
    526
    Yes share I will advise when I am not at work
  6. #26
    Aug 2007
    224
    ok thank i will share you tomorrow
  7. #27
    May 2016
    526
    I look forward to it
  8. #28
    Aug 2007
    224
    dear brother please check attachment for wiring diagram
    regards
    fsa
    Attached Files Attached Files
  9. #29
    May 2016
    526
    5 is your shot bolt and 6 is turret reverse replace them
  10. #30
    Aug 2007
    224
    ok but one more thing i want to tell you before replace the relay..that turret is working in both directions for example when i call tool #1 the turret rotate ccw direction stop at position 1 but not locked so i have to press reset button and then call tool#8 the turret rotate cw direction and stop at position 8 still not locked so i again press the reset button .........its look that turret rotate both ccw and cw direction.......NOW please tell me Sir..still we need to replace relay 5 and 6????
    regards
    Fsa
  11. #31
    May 2016
    526
    Along the top from 4 to 8 are the relays for your turret check they are working. 6 is your shot bolt had this last week changed 5 and 6 started working however you have never said it works in reverse before
    Good luck
    .as I said ages ago have you checked you are getting 24v to the turret
  12. #32
    Aug 2007
    224
    i am confused sir ..
    ok first i check 24v at turret.(please point me in attach pic where i check 24v )
    then replace relay with new one
  13. #33
    Aug 2007
    224
    ok sir as per your instruction i have check 24v DC and it is coming at turret .
    about relay ..i check relay form 4 to 8 .......and as per my understanding relay work well...
    how i checked now i am telling you .
    1st i call tool#1 the turret rotate CCW and stop the position1 (but not locked)
    now i remove relay #4 and call tool#2 but no response in fact in jog mode manual tool change is not activating.
    then i reconnect relay#4 and do same process like above mention and the turret work ..i apply this procedure on all relay #4 to 8.
    except relay # 6 all relay showing difference when connected and not connected...relay# 6 show no change either connected or not connected..\ ...........now what to do
    Sir still finding the solution..
  14. #34
    Feb 2020
    3
    Check turret motor proximity sensor gap/clearance is correct,then reset turret timing as mbservice advised earlier.this sensor could be faulty/breaking down.
  15. #35
    Aug 2007
    224
    Jono1961 thanks for join our conversation... r u talking about 6# sensor please check jpeg...highlighted with black circle?? i already maintain the gap between sensor and metal ring as per manual instruction..its 0.8mm to 1mm gap..
    2nd thing i dont know how to reset the turret timing can you guide me please
    regards
    Fsa
  16. #36
    Aug 2007
    224
    dear are you talking about this sensor can be faulty please check attach jpeg highlighted wit yellow lines..
    regards
    asif
  17. #37
    Feb 2020
    3
    See attached photos
    I - Locking control switch
    6 - also Locking Control Switch
    Sorry not certain how to upload better quality pictures
    https://www.scribd.com/doc/22636513/DUPLOMATIC-TURRET-1
    Attached Thumbnails Attached Thumbnails 345F423F-59AB-4922-B69C-C1ED45CD0CEC.jpg   4CF67949-54A8-4EE4-931D-D6C67B79FF50.jpg
  18. #38
    Aug 2007
    224
    no photo only manual of turret ...so what i do now????
  19. #39
    Feb 2020
    3
    The pictures and information are in the turret manual too if you look.
  20. #40
    Aug 2007
    224
    ok jono 1961 so your advise that i change locking control switch and reset the turret timing..but how to reset the turret timing can you guide me please.
Page 2 of 3 123
  1. Replies: 26
    Last Post: 03-02-2023, 11:25 AM
  2. Turret lost after changing turret driver battery
    By Michael82 in forum Daewoo/Doosan
    Last Post: 12-12-2019, 01:00 PM
  3. Aligning turret on a Daewoo Puma 10, 12 tool turret
    By AirChunk in forum Daewoo/Doosan
    Last Post: 06-03-2016, 02:37 AM
  4. alarm turret 1000 turret conuter error
    By aaagt78 in forum Fanuc
    Last Post: 04-08-2015, 04:14 PM
  5. colchester combi 2000 diplomatic turret.
    By Toolmaker666 in forum Uncategorised MetalWorking Machines
    Last Post: 10-06-2009, 03:43 PM
