amongst the things that have changed since the earlier version of Mach4 that you had been using is that the Lua compiler is now 5.3 version rather than 5.2.
All scripts must be recompiled against the later compiler, and that usually happens automatically but not always. If you get errors when Lua scripts are loading
it is highly probable that this is he source of the fault.
Craig
