587,541 active members*
7,902 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Chinese VFD Question?
    Jan 2017
    52
    Lightbulb Chinese VFD Question?
    Name is: "BEST" Model FC300-4.0G-S2-B4C
    4.0KW 220V
    I need help with setting the Parameters on this drive to get Spindle to working,
    My New CNC Build,
    Surely someone else has ran into one of these rascals, LOL
    Thanks fellers,,
    cubs
    15362
    Re: Chinese VFD Question?
    Quote Originally Posted by cubby View Post
    4.0KW 220V
    My New CNC Build,
    Thanks fellers,,
    cubs
    What spindle spec's do you have I have that manual they are quite easy to set
    Mactec54
    Jan 2017
    52
    Thank You so much Mac, I've fooled with this thing all day,, All I got it to do was Jog the Spindle, This is on the Motor Plate.
    Model- GDZ105X102-3.5
    Volts- 220v
    HZ- 300
    RPM- 18,000
    KW- 3.5kw
    Amp- 15 amp
    Is.F - Poll 2
    15362
    Volts- 220v
    HZ- 300
    RPM- 18,000
    KW- 3.5kw
    Amp- 15 amp
    Is.F - Poll 2
    You should not be doing any jogging with a spindle like this, they are so easy to fry if you have the Parameters set incorrect so don't run it until I have time to spend on getting the parameters set for it, so no jogging
    Mactec54
  1. chinese spindle question(s)
    By vpl in forum Spindles / VFD
    Last Post: 01-15-2018, 05:05 PM
  2. Question for Chinese Mill users
    By cnczoner in forum Benchtop Machines
    Last Post: 01-29-2010, 08:12 PM
  3. another chinese laser question
    By fogassa in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-28-2008, 09:25 PM
  4. Another Chinese Laser Question
    By pedroman in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-10-2007, 04:11 AM
