Hoping Someone is still checking these old posts rather than start a new one and id like to keep the information here. After long searching this seems to be the closest thread to the issue were dealing with on our VMC15. The Baldor Inverter does throw a fault however I can manually control the spindle from the keypad and it functions fine that way however if i try to run a program it wont rotate the spindle at all even for a tool change. The encoder was replaced a couple months ago so that is ruled out. I suspect it must either be the fault line wire to the spindle card or the card itself, or the interface pcb at the inverter. The wiring appears fine on visual inspection however i need to get a longer cable for my DVOM to check its continuity. Has anyone seen this before where the inverter still functions from the touch pad without machine running a program? I'm considering swapping the spindle card and i believe our 4020 has the same card so i could remove it and test but i need to verify part number that before i risk damage to a card from a functional machine. Perhaps it could still be an inverter issue is why i'm asking i don't know exactly how it all works to narrow it down further. I did obtain a manual for the inverter but it will take me a few weeks to read through it all. What was the result of the few others i read here that had error 9? Did you guys end up replacing the inverter?
