587,818 active members*
3,112 visitors online*
IndustryArena Forum > CAM Software > Mastercam > adobe illustrator file
Results 1 to 11 of 11
    Mar 2008
    16
    Has anyone had the pleasure of opening a file used by an ADOBE ILLUSTRATOR PROGRAM...(ei file)it doesn't seem to come in right
    Oct 2008
    47
    Hi, I just found out how to make a jpg file in to a vektor file with closed clean and single "no bul****" vektor lines suitable for cnc machining / engraving or venyl cuting or what ever.
    Import jpg to illustrator.
    Mark the jpg, then go: Object > Image Trace > Make, then tweak settings as desired in image trace window/toolbar > Object > Image Trace > Expand, > In the Pathfinder toolbar hit Merge one time (or two times) then also in the Pathfinder toolbar hit the Outline button.
    It should work to export it as pdf / dxf, or in my case just open it in Rhino3D as an .ai file.
    Mabe you knew mage you didn’t. I didn’t. So I had to share it some ware
    Bles you all.
    Re: adobe illustrator file
    Now You Can Easily Save Image to Any Format, Adobe Illustrator's Latest Version Support all types of formats.
    Here is a list of 10 best laptops for adobe illustrator for running software like adobe illustrator without any lag. https://tenrater.com/best-laptops-fo...e-illustrator/
    May 2015
    686
    You could try renaming the .AI file to .PDF
    PDF is the native format used by Illustrator.
    But Illustrator also will export to .DXF which comes into most CAD programs.
    And yes, years ago Adobe had a program called Streamline that allowed conversion of bit mapped images to vector format. But now its been incorporated into Illustrator.
    Rod Webster
    www.vehiclemods.net.au
    Dec 2008
    3136
    Thread is 6 years old..... OP has probably upgraded the software .... or junked it
    Oct 2006
    259
    Superman...... !!
    Feb 2021
    Your list is great but I think, this guy has a great taste. https://bestlaptopempire.com/best-la...r-illustrator/
    Mar 2021
    If you are searching for Best Laptops with Fingerprint Scanner And Touch Screen, then you are at the right place.
    https://www.laptophop.com/best-lapto...print-scanner/
    Mar 2021
    Are you searching for Best Budget Gaming Laptops Under 1200 USD Dollars? And you don’t know which laptop is best for you. Don’t worry; I am here to solve your problem.
    https://www.laptophop.com/best-budge...ps-under-1200/
    Mar 2021
    You can convert Image to Any Format with Adobe Illustrator's Latest Version. this version is lost data everytime so i recommended back up software. some backup softwares are avaiable here.
    https://www.techrudraji.com/2021/03/...-business.html
    Oct 2021
    If you are looking for the best laptop for adobe illusratrator then please do visit the given link. This is the latest list of the 10 best adobe illustrator laptops. you will be happy to see the latest 2021 list for these laptops.
    https://www.mirlaptops.com/best-budg...e-illustrator/
  1. Adobe Illustrator Files
    By jrmach in forum BobCad-Cam
    Last Post: 08-19-2013, 09:53 PM
  2. importing from Adobe illustrator
    By fourperf in forum Solidworks
    Last Post: 11-29-2010, 08:43 AM
  3. Adobe Illustrator and TMcad
    By LenMcC in forum Torchmate
    Last Post: 03-30-2009, 05:59 PM
  4. Adobe indesign and illustrator
    By dpmulvan in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-18-2007, 08:31 PM
  5. Adobe Illustrator Files
    By JOE65 in forum Autodesk
    Last Post: 02-09-2004, 11:20 PM
