603,781 active members*
2,567 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Spindle + VFD Questions
Results 1 to 7 of 7
    15362
    Re: Spindle + VFD Questions
    Quote Originally Posted by Blendwood View Post
    Thank you for response, and yes I'm running on single phase, 220v. So I should expect to run a vfd rated at twice the amps for single phase to get the full range of rpm from the spindle. As far as the 10,000 rpm lower end limit, does that change if you use a water cooled spindle? Or is that a torque fall off below that?
    Also one last question, other than buying a mafell or amb, does anyone know of a spindle that will range between 5,000-18,000 rpm?
    Thank you again for your time,
    Travis
    Water cooled spindle are normally 6,000 RPM to 24,000RPM some will go as low as 3,000 RPM depending on manufacture
    Mactec54
    Aug 2015
    11
    Thanks Mac, I'll have to do a bit more looking
