yeah, well, those types of compressors you are suggesting are not usefull for this, not for me at least.....11L/min@8bar for the one you linked...that is waaaaaay to small to drive anything i have. Lets say the 40L tank i ordered should sit at 8bar, then it would take 40L * 8bar / 11[L/min] = 29minutes just to fill the tank...and on top of that it only allows for a 50% duty cycle(15min on/15min off), so it'll take an hour to fill it ;-) Maybe i could live with that since it won't need any air after pressurization, but i also have pistons inside the toolchanger and the toolclamping in the spindle is also pneumatic...and there is a airseal in the spindle that requires constant airflow...and i was also planning on using aircooling for some cuttingtools which requires a huge amount of air...and a airblast-gun is also handy for clearing chips... it requires a LOT of air when everything is added up...
I think anything below 100-150L/min@6bar will be annoying to use for any sizeable machine. I'm planning on using hand airtools in my shop/garage aswell, so i'm looking at 400-500Lmin@8bar...and if i have to consider my next door neighboor then a screwcompressor is kinda my only real option because of the relative low noise level...
The oilmist is not an issue unless you need the air for painting, airbrushing or similar, but that can be easy fixed with a inline filter...
/Thomas
