588,076 active members*
5,025 visitors online*
Results 1 to 3 of 3
    Question polar coordinates
    Hey!
    I wonder how I can programming polar coordinates. In the past I worked on a Heidenhain system where I programmed with "CC X0 Y0" the center of a circle and with "LP/CP P40 R30 F800" the traveling distance. (LP=G00/G01 CP=G02/G03 LP=angle R=radius)
    Is it possible to programming that on a Okuma OSP-300-M system?
    And my second question... is there a G-Code or something else to meet the contour?
    Jun 2015
    4169
    Re: polar coordinates
    hy just did a quick search, and i found something in attached manual, about i-map
    i don't understand what you mean by "meet the contour" / kindly
    Mar 2009
    1982
    I guess "meet the contour" is tangental snap to existing shape. For instance, a circle meets the segment of ray under an angle.
    That kind feature comes with IGF.
  1. POLAR COORDINATES
    By G0Z0 in forum Uncategorised CAM Discussion
    Last Post: 11-20-2017, 04:28 PM
  2. Bi-polar/Uni-polar motor P.S amp selection
    By sahilkit in forum Stepper Motors / Drives
    Last Post: 02-03-2012, 06:48 AM
  3. Polar coordinates
    By Blackbumpkin in forum Deckel / Dialog
    Last Post: 04-27-2009, 04:19 PM
  4. Uni-Polar or Bi-Polar, or does it matter?
    By imagineer in forum Stepper Motors / Drives
    Last Post: 12-05-2006, 05:53 PM
  5. Electronic Utopia Bi-Polar Board (or other Bi-Polar boards)
    By ranman in forum Stepper Motors / Drives
    Last Post: 05-29-2005, 02:25 PM
