587,737 active members*
3,130 visitors online*
Results 1 to 16 of 16
    Mar 2017
    9
    losing steps between layers on 1 axis
    Wondering if anyone else has experienced this issue, this just started over the weekend?
    Running a China Zone 60x90
    All 3 axis are calibrated and move accurately when doing the calibration distances
    Everything on the first pass is correct to scale
    When going for second pass Y axis is always less than where it is supposed to be. It not a constant number off, just always less.
    That pass is then done perfectly other than it keeps shifting on the Y axis.
    I was thinking maybe my G code got messed up somehow, but I hit stop after it began the 3rd pass and then jogged back to my Y limit and found the CNC thought it was 15mm away from the y axis being at 0, so I think I am at a hardware issue.
    Not sure if something in the motor is not counting the steps correctly in rapid movement, or if something else.
    I am going to make a simple 3/4" box tonight and see what happens
    I think I am going to try and swap X and Y stepper motors see if it follows the motors.
    After that I guess I would be at swapping out X and Y controllers to see it if follows them
    Thanks in advance, any ideas are welcome...I like to have some type of game plan ready when I get home to figure this out
    Apr 2004
    475
    Re: losing steps between layers on 1 axis
    15mm is a lot of steps out.
    Yes, swapping components is easiest to test.
    Swap wires first, drivers second, motors themselves last and test (when the motors are off) for how much force is needed on the coupling to see if one axis is binding somewhere.
    Actually, check for loose wires first.
    But, if the size of layer 2 and 3 are ok, then it might be interference from the z that is causing the issue.....that's less likely than just loosing or gaining steps along the cut line though.
    Good luck
    Sent from my Nokia 3.4 using Tapatalk
    Mar 2017
    9
    So I made a 10x10 box 3/4" deep and it cut out as expected
    I took my previous file which was 6 different cuts and ran each portion separately and it cut perfectly
    Since I ran each separately, I am thinking more of the steps being lost in the rapid movement between the cuts when they are in one file
    Mar 2017
    9
    Update as I am still having issues...
    I had been told to check the coupling tightness on the screws and all that was fine, that maybe it was just slipping occasionally, since it was so random. Well I was going to run a simple spoil board flattening when the bug hit the machine and I caught it. In the middle of everything the stepper motor just shutters for a few seconds but Mach 3 still thinks it is moving then it just starts going again but it is now about 20mm off course. By shuttering I mean the knob of the motor was just going back and forth about a millimeter. The g-code for the spoil board is simply going down, then going back and forth so there was no intricate movement when this happened, just going from x25 to x575. But when it came back on the next pass it hit the limit switch because it never got to x575 but thought it had. This has happened in both the X and Y axis. I am not driving the unit very fast so I don't think that it is an issue of skipping steps, and I can easily manually turn the screws so it's not in a bind. I think either the motors are bad or the controllers are not providing enough voltage sometimes just for a brief moment. What do you think? I have seen so many different manufacturers and do not want to buy more junk if I have to upgrade controllers or motors, or both. Thanks for your input.
    15362
    Quote Originally Posted by tjcham01 View Post
    Have you done any wiring improvements Ground wiring is normally quite poor on these machines?
    What does the spindle to VFD Drive wiring look like, have the used a 4-wire shielded cable?
    Is there an EMI Power Filter?
    Could also have the Velocity / Acceleration set to high also.
    Post some photos of the cabinet wiring
    Mactec54
    Mar 2017
    9
    I have not done any wiring improvements. It appears the ground goes to the power supply, the EMI filter and the VFD, I don't think it is bonded to the enclosure
    The VFD spindle has a 4 wire conductor, but if it does not appear to be a shielded wire.
    Yes there is an EMI filter under the motion card
    It is not going very fast so I do not believe this is the issue.
    Thanks for looking and helping.
    15362
    Yes, this is a crowded mess, the filter is most likely only suitable for the Power supply, the output of the VFD U V W is where most of the problem is coming from, the input is not that great as well, do the drives have a Ground wire.
    When the main Power enters the cabinet what does the Ground wire do, is it connected to a Grounding Stud or Bus.
    Mactec54
    Mar 2017
    9
    Using the pictures and my memory on this...the ground at the source plug has 2 wires on it. 1 wire goes to the power supply the other to the EMI filter where it has another wiring wire leave and go to the VFD. It did not appear to be bonded to the enclosure or go anywhere but to those 3 devices.
    The only wires on the drives seem to be 2 wires from the 24volt source, the 4 wires for the motors, the 3 wires from the controller and a jumper from the PLS+ to the DIR+ on the drive which comes from the 5V on the controller
    15362
    Thats not ideal but should work for those Items, so is there a Spindle Ground where does that go.
    Is this a water-cooled spindle?
    Check the 4th Pin at the spindle to see that it has continuity to the spindle body, and the Plug has a Ground Back to the Box
    Mactec54
    Mar 2017
    9
    yes it is a water cooled spindle
    the 4th pin at the spindle has continuity to the spindle body and the box, I missed that wire before, it is connected directly to the power supply ground
    Think I am going to get some shielded wire and replace the wiring
    15362
    You have to add a Ground Bus or a Single point Grounding Stud in the cabinet, this would be attached to the cabinet, (Remove the Paint wherever you mount anything) all Grounds need to be connected at this one point. (Star Point)
    IGUS has the best shielded cable, what is the spindle size, and I will give you a Cable part number, when you replace this cable, you need it as one piece from the spindle to the VFD Drive
    so just a Gland or gromet where it enters the case, the shield also needs to be correctly terminated so when you get to that part, I will give you some guiding snips
    Spindle Kw=
    Mactec54
    Nov 2019
    11
    I had a steps-skipping problem once, turned out to be a failed fan in the control box, and simple overheating. Something in the silicon wasn't making timing when too hot. Mercifully it was not a hard failure, and cleared up after I replaced the fan. Worthwhile checking that your fan is running.
    Yesterday my Z-axis was not functioning. Motor did not even hold tight in a static position when the drive was powered up. I swapped in the spare (rotation) axis driver, and everything is back to normal. Pulled the bad driver and the electrolytics are exploded. Different from your problem.
    Mar 2017
    9
    2.2kw spindle
  1. Z axis losing steps?
    By grubscrew in forum DIY CNC Router Table Machines
    Last Post: 03-15-2015, 09:52 PM
  2. Losing steps in the Z axis!
    By subnoize in forum X3/SX3/G0619/G0463
    Last Post: 05-12-2014, 10:00 PM
  3. Z axis losing steps
    By nlancaster in forum DIY CNC Router Table Machines
    Last Post: 03-31-2014, 03:30 AM
  4. Losing steps in Z axis!!
    By Westozy in forum DNC Problems and Solutions
    Last Post: 12-15-2009, 09:35 PM
  5. Losing steps with the Y axis
    By norman roy in forum Tormach Personal CNC Mill
    Last Post: 12-23-2008, 03:29 AM
