Re: GE Fanuc & FANUC proprietary posts
The whole issue that caused Fanuc to start clamping down, was some time ago, someone published and distributed on the net, most of the 'proprietary' settings that turned on added features that are available to be paid for at the time of purchase of the system, or later purchase by the end user.
These options are in the control, it usually just requires a setting of 1 bit of memory to turn them on. Some require some hardware as well.
I may or may not have a copy.
I have known some users to back up their system, and then 'experiment' by turning on random option 'bits' to see what transpires.
Albert E.
