587,671 active members*
3,470 visitors online*
Results 1 to 6 of 6
    Apr 2013
    110
    incorrect processing display
    Hello everybody,
    I resumed using my cnc pantograph after a year of stoppage, I updated TNG V2 to the latest version and I uploaded a gcode of a very simple rectangle. I find myself displaying the whole path wrong. I probably missed something in the various updates of this last year but I can't figure out if it's a setting or a bug. As you can see from the attached images, the piece to be machined is a very simple flat rectangle milled in 4 passes but the display is mirrored and tilted .... where am I wrong?
    Any help is very welcome
    I haven't changed any parameters since the last time I used it and the display was correct
    I use the P.P. of Vectric in the TNG examples but the same thing does it using the P.P. of Mach2 / 3
    Marco
    Mar 2017
    1329
    Re: incorrect processing display
    Please post your profile file and your gcode program.
    File/Export Profile
    Apr 2013
    110
    The required files are attached. Thank you
    Apr 2013
    110
    some news ?
    Mar 2017
    1329
    Your A axis is not at zero.
    In setting "User Interface/3D/Geometry/XYZ" setting "Rotation" is enabled. Because of this 3D display is rotated to match A axis position.
    Either disable this setting or set A axis to zero.
    Apr 2013
    110
    Okay, I'm a fool. I recently mounted the 4th axis and I have not yet understood how it works.
  1. incorrect tool path on table display
    By moswede in forum CamBam
    Last Post: 04-08-2022, 09:31 PM
  2. incorrect tool path on table display
    By moswede in forum SmoothStepper Motion Control
    Last Post: 02-10-2022, 09:55 PM
  3. Extra Circles In Mach3turn. Incorrect NC Display
    By Actor28 in forum Mach Lathe
    Last Post: 11-13-2020, 02:51 PM
  4. Mcam: incorrect display of DXF
    By alleszerspaner in forum Mastercam
    Last Post: 11-16-2011, 08:59 PM
  5. Incorrect data processing B
    By Dieter78 in forum HEIDENHAIN -> GENERIC
    Last Post: 04-09-2009, 09:22 PM
