587,319 active members*
3,327 visitors online*
Results 1 to 9 of 9
    Mar 2007
    10
    Convert g2 g3 r to g2 g3 ijk
    Hi, what is the formula to convert a G2 or G3 command with R option to IJK option? my CNC board only accepts IJK version But some CAM software only output the R version. I am sure that this was talked before, but i cant find almost anything.
    Thank you,
    Dan
    Jun 2015
    4156
    Re: Convert g2 g3 r to g2 g3 ijk
    hy if you can't fix your postprocessor, i can help you
    ijk are more or less control specific ( try i for x axis, and k for z); represents the signed distance between center and start-point; pls check also attached
    also tried to sent you a message / kindly
    Mar 2007
    10
    deadlykitten, i dont have a lathe, i have a router.
    I need to transform g2 xyr into g2 xyij.
    Jun 2015
    4156
    pls, active your private message
    also, you may find attached generic ijk for milling
    some cnc editors have the options of converting files , ncplot for one does
    Mar 2007
    10
    metalmayhem, thank you for reply, but i need the theory to implement it in my software.
    deadlykitten, i have checked all my settings, private messaging is activated, i can receive messages from everyone. I know what IJK are, i want to calculate them only from start point, end point and radius. User Kiwi had made a small piece of software that calculate exactly that, but he is not active anymore...
    Mar 2007
    10
    This is the software, i need the theory behind
    Attached Files Attached Files
    Jun 2015
    4156
    pls, try to send me a message
    Jun 2015
    4156
    hy, i can't reply pls, if you wish, leave an email
  1. G code issue with arc ijk
    By gr3g0rs in forum Autodesk CAM
    Last Post: 06-28-2017, 10:19 PM
  2. Jittering around IJK moves Fusion 360
    By Browellr in forum Autodesk CAM
    Last Post: 02-24-2017, 08:39 PM
  3. Mach skipping code, absolute IJK errors!
    By moparx12 in forum G-Code Programing
    Last Post: 01-03-2017, 04:11 PM
  4. Changing output from XYZ to IJK
    By greenmax in forum GibbsCAM
    Last Post: 03-13-2014, 06:16 PM
  5. Drilling Problem with IJK
    By Joe Engel in forum Fadal
    Last Post: 12-28-2007, 07:27 PM
