587,776 active members*
2,461 visitors online*
Results 1 to 12 of 12
    Jul 2016
    85
    Mach skipping code, absolute IJK errors!
    Hi guys,
    I'm totally new to this but I did have some success with my new CNC router on a more simple project previously. When I load this code though, Mach jumps to line 7852 and does not move (router on or off). I also get an error that says: Delta: Internal error![movement error]. I am hoping there is something obvious wrong with the first few lines of code causing it to do this. I thought maybe it was a loose wire but I can run other code via the wizards in Mach just fine.
    Thanks!
    Mar 2003
    35538
    Re: Mach skipping code, absolute IJK errors!
    I've never heard of that error, and suspect it's from the motion controller plugin?
    Where did that code come from? Did you use a Mach3 post processor?
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Jul 2016
    85
    Hi Ger
    I used a Fanuc post for this particular code. Is there something obvious in there that wont work with Mach3? I do have a USB motion controller card from China, maybe I should look into the problem there? I get the error with the router electronics (including controller board) off though so could it still be caused by that?
    Mar 2003
    35538
    I can't check on the code until later this evening.
    Your title says IJK errors, but you didn't mention them in your post? Are there other error messages?
    Gerry
    Jul 2016
    85
    I need to pay more attention and try this again at lunch time, but I was getting that IJK error upon pressing cycle start after Mach3 had jumped to line 7852 of some 10000 total lines.
    I looked at an online gcode simulator and saw that it was having a hard time understanding the bolded line:
    G43 H1 D31 G0 X-1.173 Y-37.176 Z5 S10000 M3
    M8
    (HSR-R-CONT-TARGET - HSM-AREA-CLEARANCE)
    X-1.173 Y-37.176 Z1.
    Z0.297
    Can I re-write these lines to:
    H1 G0 X-1.173 Y-37.176 Z5 S10000 M3
    M8
    Z0.297
    I am not sure if its the G43 or the D31 but the quick n' dirty online checker did not like those.
    Mar 2003
    35538
    Neither of those lines are correct.
    G43 should not have a D word, and that should really be 3 separate lines.
    What software is this? DO you have a Mach3 post processor?
    It should be
    G43 H1
    S10000 M3
    Gerry
    Jul 2016
    85
    I do not have a specific post for mach yet. I will try re-writing that line and see what it does at lunch time. Thanks
    Jul 2016
    85
    ok, so i changed that line of code to the 3 lines you provided. That did not immediately work but for the heck of it (i'd read it here somewhere) i switched the CV mode off... I was able to then run the code from the beginning. I still had to "rewind" it to get there because I still get the error at line 7853 (not 7852 like I previously stated). I went ahead and ran the code and it stopped once again at line 7853 and an error message stated something to the tune of: "current point same as previous point". should I just delete this line or 7854?
    7852: X-5.001 Y-35.623
    7853: G2 X-5.001 Y-35.623 R0
    7854: G1 X-5.001 Y-35.623
    7855: X-5.035 Y-35.54
    Mar 2003
    35538
    Remove 7853 and 7854, and change 7855 to
    G1 X-5.035 Y-35.54
    7853 is an arc with a radius of 0, and a length of 0.
    7854 is a linear move with a length of 0.
    Gerry
    Jul 2016
    85
    Thanks Gerry! Ill buy you a beer next time I see ya!
    Mar 2003
    35538
    I edited out all the bad lines, and uploaded the edited version. (I upped a lot of the feedrates so that I could simulate it faster, so don't try to cut anything with it.)
    This code was poorly written, with a lot of errors.
    I think that original error was from your motion controller.
    Attached Files Attached Files
    Gerry
    Jul 2016
    85
    thanks again Gerry. I found that my post was written to output only 2 decimal places so I changed it to 3 in the .txt file and all seemed to be OK. Now i am just chasing a sync issue with my leafboy77 usb breakout board. I think it is a noise issue but not sure. Going to try a usb cable with ferrite chokes as soon as i can find one.
  1. Mach is Skipping lines of G-code!!!
    By RedCNC3 in forum Machines running Mach Software
    Last Post: 12-23-2011, 09:47 PM
  2. Fanuc 6T skipping over program code
    By mzk_t32b in forum Fanuc
    Last Post: 10-16-2011, 09:21 AM
  3. Haas Sl-30 skipping code
    By MBG in forum Haas Lathes
    Last Post: 03-10-2009, 01:51 AM
  4. Skipping Line Code???
    By bvweld in forum DynaTorch
    Last Post: 09-24-2008, 06:16 AM
  5. Deskcnc Skipping Lines Of Code
    By bradyfb in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-08-2007, 11:59 PM
