603,790 active members*
5,965 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > how can I control a stepper with an encoder?
Results 1 to 5 of 5
    Oct 2005
    36
    Hi all
    I need to be able to contol a motor simply by turning an encoder shaft and have the motor respond in position, velocity, and direction accordingly.I need a schmatic of stepper controller with an encoder.
    I find about this subject in internet. http://www.webx.dk/oz2cpu/20m.htm
    how to connected this circuit with stepper controller.?
    thank you any advice would be nice.
    nasr1.
    Jan 2007
    42
    I think that is a circuit to use a stepper as a shaft encoder. It looks like it produces two outputs which will be square waves 90 degrees out of phase with each other as the stepper is rotated.
    Jan 2007
    42
    To drive a bipolar stepper you would simply need to amplify the two signals to provide sufficient voltage and current for the coils. To drive a unipolar stepper you would need a couple of inverters to make the four signals before using a drive chip to amplify them.
    Oct 2005
    36
    Quote Originally Posted by nophead00 View Post
    Thank you for response.
    Do you have a schmatic of stepper controller with an encoder.?
    Jan 2007
    42
    Sorry I don't have a schematic. You don't need a stepper controller with this scheme, just a driver chip. The type of driver chip would depend on the specification of your motor. As a simple example to drive a small uniploar 12v motor up to 0.5A per winding you could use something like a ULN2803. It has 8 darlington drivers and you can connect them in parallel in pairs to make four higher current channels. You could take the A and B outputs of your example circuit and invert them with somthing like a 74HC04 to make A-INV and B-INV. Feed those four signals into the 2803 and connect the outputs to a unipolar motor. These have two center tapped coils. Connect the taps to 12V. Make sure connect the outputs correspoing to A and A-INV to one coil and B and B_INV to the other.
    Connect a small stepper with the same number of steps J1. When you turn it the output stepper will follow provided you don't go very slowly or too fast.
  1. Big PacSci Stepper with Encoder
    By sdantonio in forum Stepper Motors / Drives
    Last Post: 06-21-2006, 04:26 PM
  2. Can DRO encoder be used for motor control?
    By bicycleboy in forum Gecko Drives
    Last Post: 05-03-2006, 10:59 PM
  3. encoder-stepper motor
    By granado in forum Stepper Motors / Drives
    Last Post: 11-29-2004, 11:38 AM
  4. Stepper with 200 cpr encoder
    By mdoan in forum Stepper Motors / Drives
    Last Post: 10-22-2004, 02:59 AM
  5. Stepper motor with encoder?
    By buscht in forum Stepper Motors / Drives
    Last Post: 07-13-2004, 03:53 AM
